    **VIEW RULES HERE**
La Candelaria - Occre Build log
Thanks El Capi, I kind of figured as much but being a first time ship builder I'm not that familiar with the names of some of the parts. Occre's instructions doesn't say what each individual parts are ether.
I have just sent a few pages with the most common terms, but it looks like going to the wrong person- either Endeavour or Candelaria. If you can find them I will send them again.
HERE THEY ARE
HERE THEY ARE
Thanks El Capi,a very comprehensive list. This will help me & anyone else out who does not know the names of various ship parts. I'll be consulting this post as I build my ship. Much appreciated:)
More tiny parts to be made & this time it's 12 posts as seen in the photo instructions along with 2 posts that are almost complete except for the mortise that will be cut for the belaying pin board. IMG_6763.jpg
The posts are cut out of 4mm square stock 16mm long. First step is to file the top bevel & I used my miter box placing the work piece at the 45 degree slot. A brass pin is used for a stop & a finger nail file to cut the bevel. IMG_6767.jpg
The 4 sided mortise is cut using a jig I made out of aluminum bar stock. The bar stock is 1.5mm thick so 2 pieces = 3mm which gives me a 1mm mortise. A third piece on top of these makes up the 2mm wide channel needed to file in the mortise. I made 2 of these to sandwich the work piece in place & then file the 4 sides.IMG_6772.jpg
Now it's back to the miter box to cut the post to length. Again a stop is used & set at 16mm. If I had a hobby table saw I guess that would have made the whole operation a lot easier.IMG_6773.jpg
I have been pondering for a while on how to do those mortises that cleanly… nice thinking!! Unfortunately, I don’t carry metal bar stock, nor do I have the means to work with it, so the gears are still turning. One pricier option that I have been considering for quite some time, even before ship building, is a mini-mill.
FYI, just in case… I had been using the stock photos on ModelExpo to occasionally reference. Looks like they no longer carry Candelaria… page is completely gone. If you search for it, the only thing that comes up is the paint set. I went over to OcCre’s site, and they still have the page up, but it’s shown as “sold out”. Not sure if it’s being discontinued, but I downloaded the pictures to have them in case it disappears.
Frank, the aluminum bar stock was bought at Ace Hardware & it's $5.00 for 3 ft. at 3/4" by 1/16" thick. Nothing fancy on my part, I just cut what I needed with a hack saw & glued the pieces together with CA glue then temporarily screwed them to the work bench. I made 2 jigs out of it already- 1 for the post above & 1 for the Samson post. Just in case your interested.
That was a pretty ingenious solution... I will admit I would've never thought of that!
I finished the Belaying pin boards (if that's what their called) & the small shack this last week.
Also worked on & finished the chicken coop. I marked out & drilled holes for the pins then inserted a spacer before pushing the pins through the top & nailing them into the bottom. The last photo is the completed chicken coop.IMG_6852.jpgIMG_6857.jpgIMG_6877.jpg
Question about this balaying pin rail. The drawing calls for 15 holes (mine has 14) but only 9 are being used as I see it. With the one I made the pins are very close together & I'm thinking that it will make it harder to tie down the ropes. If only 9 pins are being used could I just make a new rail with less holes spaced further apart?IMG_7200.jpg
To scale the belaying pins you are supplied with look over sized (too thick). There should be more pins than are necessary per rack. If so, you could eliminate one or two. See if you can find a supply of belaying pins of a more suitable size I find the turned brass ones are usually more suitable and can be blackened or at least given a brown patina. More work, but that's modeling.
Peter, the pins in the above photo have not been painted & yes they do look oversized. I'm past the point of buying smaller pins as seen in this photo with the fife rail & forecastle pin rail already installed. I was able to space the holes further apart for the rail on the forecastle deck which made it longer then on the plans but that's O.K. with me. I really can't do the same with the rail between the cannons but was just thinking of using less pins.IMG_7192.jpg
Peter, the pins in the above photo have not been painted & yes they do look oversized. I'm past the point of buying smaller pins as seen in this photo with the fife rail & forecastle pin rail already installed. I was able to space the holes further apart for the rail on the forecastle deck which made it longer then on the plans but that's O.K. with me. I really can't do the same with the rail between the cannons but was just thinking of using less pins.View attachment 434284
As long as you have enough for lines to be secured (You can erven double up. This was not unheard of.)
Ship looks gorgeous, by the way. Nice pristine work Thumbs-Up !
you can easily make new ones using the Tooth sticker- the wood is very good and with a Dremel no problem- an old RAT. 50 years plus building
Here's my process for fitting the cannon carriage wheels to the axles. Occre tells me to use brass rod for the axles but the rod is too small for the wheel holes making for a sloppy fit. It took me a few days to discover that a tooth pick is just the right size for the axles which was great because who doesn't have a pile of
tooth picks:). I dry fitted the wheels to the axle then fitted it to the carriage & poked tiny pilot holes on the axle for the brass pins. Using my handy dandy Arrowmax I drilled the holes for the wheel pins & snipped them to size.
It's a good feeling when a homemade solution works out & that Arrowmax drill is becoming one of my favorite tools. Couldn't imagine drilling those holes with a hand pin vise.IMG_7663.jpg
