Amazing work with al those details of the walls Uwe
Good afternoon Uwek. Your work is brilliant. Some prison cells up front I see…Hallo my friends,
many thanks for your replies with the comments and suggestions - I have to consider these ideas especially for the one wall which will be close to the carrick bitt pin..... still I have some time to think about it
I added a little bit of the "iron"-works on the doors - the walls are still only dry fitted - but in the meantime the wood is treated with CLOU
and I realized, that the second bitt pin needs a notch through the deck planking
Many Thanks for your interest in my log ....... to be continued .....
. I don’t know if it will “grow” on you, however as you build more the effect of the bulkheads and cabin walls above the cut is becoming effective….My humble opinion. Cheers Grant
Good afternoon Uwek…. From what I can see this is spot on.Many Thanks to all for your comments, all the likes and the high interest in visiting my building log - highly appreciated and a big motivation
after the preparation of the walls of the fore platform, I jumped "backwards" to aft and worked some hours on the so called "after platform"
View attachment 435781 View attachment 435782
It was already 1 1/2 years ago, in September 2022, when I was preparring already the first elements - now step by step I have to adjust and finalize them
I recongnized that at this time the "fore bulkhead of the lower rooms" (#20) was not really fitting the ciurvature of the iinner planking, so I added one more layer
now these vertical planks are long enough to reshape the curve
much better than before
nobody will see thes walls in the hold ..... but
Many Thanks for your interest .... to be continued .....
No one will see the walls in the hold, but the man who built that beautiful ship will know! Fantastic work and skill.Many Thanks to all for your comments, all the likes and the high interest in visiting my building log - highly appreciated and a big motivation
A nice build and nice pictures, PeterMany Thanks to all for your comments, all the likes and the high interest in visiting my building log - highly appreciated and a big motivation
