HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Hallo my friends,
many thanks for your replies with the comments and suggestions - I have to consider these ideas especially for the one wall which will be close to the carrick bitt pin..... still I have some time to think about it
I added a little bit of the "iron"-works on the doors - the walls are still only dry fitted - but in the meantime the wood is treated with CLOU
and I realized, that the second bitt pin needs a notch through the deck planking
Many Thanks for your interest in my log ....... to be continued .....
Hallo my friends,
Good afternoon Uwek. Your work is brilliant. Some prison cells up front I see… ROTF . I don’t know if it will “grow” on you, however as you build more the effect of the bulkheads and cabin walls above the cut is becoming effective….My humble opinion. Cheers Grant
Witaj
Piękna praca i zdjęcia , bardzo podoba mi się zdjęcie przed ostatnie rzut z góry . Pozdrawiam Mirek
Witaj
When it comes to the area, you can also see the area in the mountains. Pozdrawiam Mirek
Many Thanks to all for your comments, all the likes and the high interest in visiting my building log - highly appreciated and a big motivation
after the preparation of the walls of the fore platform, I jumped "backwards" to aft and worked some hours on the so called "after platform"
It was already 1 1/2 years ago, in September 2022, when I was preparring already the first elements - now step by step I have to adjust and finalize them
I recongnized that at this time the "fore bulkhead of the lower rooms" (#20) was not really fitting the ciurvature of the iinner planking, so I added one more layer
now these vertical planks are long enough to reshape the curve
much better than before
nobody will see thes walls in the hold ..... but
Many Thanks for your interest .... to be continued .....
View attachment 435781 View attachment 435782
Good afternoon Uwek…. From what I can see this is spot on. :D Cheers Grant
No one will see the walls in the hold, but the man who built that beautiful ship will know! Fantastic work and skill.
A nice build and nice pictures, Peter
Many Thanks my dear friends - Many Thanks for all your interest
working more on the bulkhead walls - here the after bulkhead magazing
not so easy to adjust the outer form that they fit well with the interior hull planking
Here I want to show the door towards the powder magazin open - also the small door towards the breadroom
and the light box - glas is made out of Mica
dryfit
More or less ready for final installation
Many Thanks for your interest in my work and building log .... to be continued ....
Question, when you assembled the frames I noticed that you removed the laser char before mating the parts. Did you make sure when the frames were complete that the frame matched the provided frame drawing exactly?
