Always a pleasure to see your nice work!
Thank you Paul. I'm really pleased you like this. l am trying my best to make an acceptable job and you always have a good word to say which is very encouraging.Always a pleasure to see your nice work!
Thank you Daniel. Yes l often find myself thinking that exact same thing. No computers, no electric power tools, just hard accurate woodworking skills. incredible.This is great work Keef, I find myself studying the frames back and forth and wondering how those workers ever built such structures without modern equipment.
Thank you very much Hienrich for your kind words. l am trying for this weekend to close the hull because l have had some bad, but not unexpected news and it looks like the following weeks will be filled with hospital appointments. Scans, surgery and chemo. Sorry to drop this on you and this group, but l am scared and need to tell someone. Maybe l should just keep quietThis is super work Keef. I just love how clean and tidy the assembly of the frames are and how well the hull shape is coming along. I'm looking forward to when the hull is fully closed.
Thank you so much Paul. lt means a lot my friend.Please don't remain quiet Keef. Best wishes for successful medical care. I will be praying for you in the weeks ahead.
I hope to be starting the CAF Granado in a month or so. Do you feel the thick piece of pine on the bottom is necessary, and recommended by CAF? I would be a bit concerned with the pine warping, or even not quite straight to begin with, while the plywood construction frame, being a closed box, should be very resistant to torsion or warping. I do understand about the weight, though. Just wondering your thoughts.With the keel now all but finished apart from CA-1 and 2 (the card slots for the midship frames) and a little cleaning and fine tuning, it's time l turned to the cradle in which the keel is held in order to accurately align each of the frames once they are constructed. The first job is to mount the base of the cradle onto a thicker piece of pine to give the structure more rigidity and add a bit of weight to stop it sliding about all over the workbench when trying to work on the model. This done, the keel is placed into its centre position to check all is correct. l'm really happy to say that it fits perfectly. So now l can continue with the construction of the cradle, which like the rest of the kit so far seems to go together very accurately.
Thank you very much Signet and please don't apologise for asking your question. The wood base l added to the jig is not mandatory. I added it solely to give the structure some added weight for stability when working on the frames. Although the model is a good size, it weighs very little. The jig is actually quite sturdy on it's own and it is totally up to you whether to add the base or not. l am having no issues with warping of the pine as it is laminated and about 22 mm thick. l personally find it helpsI hope to be starting the CAF Granado in a month or so. Do you feel the thick piece of pine on the bottom is necessary, and recommended by CAF? I would be a bit concerned with the pine warping, or even not quite straight to begin with, while the plywood construction frame, being a closed box, should be very resistant to torsion or warping. I do understand about the weight, though. Just wondering your thoughts.
Sorry, I wrote this as I started with your build from the beginning, and just now saw about your health concerns. Please accept my well-wishes and good results during your health issues. We will all be rooting for you - all of us in your build audience, and more.
Thanks for your support my friend. When you say 'template' are you referring to the hull construction jig? If so it is totally glued, using white wood glue. It all goes together extremely accurately and is very strongHello @Keef, I wish you courage in the difficult ordeals you are going through and a rapid recovery to return to us as quickly as possible.
I have a question regarding the template. Is it glued or just fitted?
For some reason, I didn't even think of using plywood (!!!!). Sure, that wouldn't warp, would provide a good base. I like that you fit the keel to the jig before completing it, and the base will certainly help with that.Thank you very much Signet and please don't apologise for asking your question. The wood base l added to the jig is not mandatory. I added it solely to give the structure some added weight for stability when working on the frames. Although the model is a good size, it weighs very little. The jig is actually quite sturdy on it's own and it is totally up to you whether to add the base or not. l am having no issues with warping of the pine as it is laminated and about 22 mm thick. l personally find it helps
