Aint that the truth!Somewhere, in your basement, dwell a clutch of gremlins, no doubt playing with the two nuts from your airbrush and giggling gleefully over your dilemma. They snatch them as soon as you start looking, and will, no doubt, replace them (in plain view) on your basement floor as soon as the replacement parts come from Amazon. I believe they get kickbacks from Jeff Bezos. I believe, also, that they must be related to the clutch of gremlins living in my basement and in the USNA model workshop, the modus operandi being uniformly the same.![]()
As a volunteer model shipwright in the museum workshop for 15 years or so.Aint that the truth!
You worked at the Naval Academy?
You are so right, every time I move something, I chip up a bit of another tile, adding to the little cubby hidey holes. I think the tiles were installed when the house was built back in the 50's soChris, I think I can see something under the compressor!
Sorry for having a laugh. Looks like there are plenty of good hiding spots in your basement. I know it can be very frustrating especially when it’s a unique part for the ship.
I hope you find it soon.
Pictures from the USNA MuseumAs a volunteer model shipwright in the museum workshop for 15 years or so.
I posted a bunch of pictures on SOS from the shop last year. And of one of the restoration projects, I worked on, restoring the model up to masting and rigging which is no in another person's hands.
That's a builder's model of the Maine. When the design was finalized, the navy did away with the vestigial masts, so they never finished the model and it became an artifact in the attic, kind of like the "Lost Ark". When they re-built the museum, years ago now, the model was brought into the shop. Two years ago, a concerted effort was put into effect to finish restoring the model according to its' original intent, masts and all.You are so right, every time I move something, I chip up a bit of another tile, adding to the little cubby hidey holes. I think the tiles were installed when the house was built back in the 50's so
I am sure 'remediation' should be followed.....
I'm going to bite the bullet and move that drawer out, the air compressor, router table and table saw and see if they are there. Sigh.....
Was a bit hard to find, still not used to the search engine. That is one hell of a shop, to have access to all those tools and other skilled modelers! Yikes!
Not sure what the warship in white and red is. At first glance I thought the cruiser Olympia, but she only had 2 masts. Some fine history there!
true storyre. paragraph #4 Welcome to the club. that forehead shaped dent in the drywall next to yours would be my own. There will come a point when you look at your model, still in progress, and say to yourself: "Damn! Looks pretty f***ing good!" Mostly of it does already! Keep on pluggin!![]()
re. paragraph #4 Welcome to the club. that forehead shaped dent in the drywall next to yours would be my own. There will come a point when you look at your model, still in progress, and say to yourself: "Damn! Looks pretty f***ing good!" Mostly it does already! Keep on pluggin!![]()
Hey Chris
Good to see you have had a period of reflection and correction.
Judging by your photos it appears as though your reparations work has been very effective.
The Victory is indeed one of the more challenging kits to build. You should not be too hard on yourself, you are doing a great job and obviously learning much along the way. That is priceless.
Keep up your assault.
Appreciate the boost guys!true story
Copper plates are for the brave and patient fellows…,,enjoy. Cheers GrantAppreciate the boost guys!
I finished touching up the gunports. I still have some minor spots to get at and needed to flip the hull upside down to get the 'top gun ports'
I didn't get any pictures of where I am so far but decided to start the copper plating. I started at 1:59pm in the first pic and the 2nd pic at 5:43pm.
I took about 30 minutes or so in the middle to each lunch and check some other builds and my books to make sure I had a plan in place for laying out the tiles.
View attachment 441071View attachment 441072
So 5 rows in about 3-3.5 hours. I'll see you when it's done!!!!
Absolutely splendidWell, it took 9 days of a little work here, a little work there. Usually about 3 hours at a time after spending time down at the marina.
I am not sure one way or another if it's ok. I did alter the runs a few times to create some areas where I am going to need stealer plates.
Also, I did attempt to add final cut pieces and after the fact, I am not happy. I used a regular pair of scissors to cut the plates and that was fine, but it does warp the plate. After a first attempt, I removed a lot of the little wedges and I'm going to wait till I'm done and circle back around.
I can see some areas where the CA glue is visible. Once I'm done, I'll see if Q-tips and acetone can help remove that. I've seen other builds where any attempt to work at the finished plating is worse.
Hopefully, filling in the wedges goes well! So on to the port side and I'll see you soon!!!!
Oh, I have been working on building the cannons. I have been cutting them out about six at a time and building the bases....just something to keep my sanity.
View attachment 442737View attachment 442738View attachment 442739View attachment 442740View attachment 442741View attachment 442742
View attachment 442743View attachment 442744
