HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
In the meantime the cover elements were also final sanded and painted red (information to @Dubz Modelling World : I am still think about this wall - and I am pretty sure, that I will reduce it like I showed in post #1.604 to a minimum - I still do not know if I will imitate some nailing )
I have to make some photos with pure natural light - the red is not so pinky like sometimes in the photos
On this photo the red color is shown more like real
Here now added are these four board covers and all necessary eyebolts
Here the joints are also "caulked" to protect against sea-water -
also here :
nailing or no nailing? that is the question
The complete arrangement
Like mentioned earlier - everything is removable and can be dismantled to show the mortars "ready for Action"
Many Thanks for your interest in my building log and my work .... to be continued
also here :
They are looking very nice, Uwe. You opted for the caulking detail, so my option would be to ad also the treenail details.
I like the overall appearance, mon ami. It could be possibly too much with nails, but tiny holes would be just right, IMHO). However, I hope you don't mind, the eyebolt's head is kind of out of scale, the same size (at least what it seems to be) as the ring itself. Maybe it is just macro reveals, and it looks OK on the model itself, but it just caught my attention.
Yes - I make maybe the "nailing" with only some pushed holes with a marking pin / scriber
Do you mean the ring or the eyebolt? too big or too small?
I know, that often the ringbolt is smaller than the ring, like on this example
This is often the case, when a rope is going trough the ring f.e. as a tackle
I was trying to follow mainly the sketch made by Goodwin
The ring is shown with 3,3mm outer diameter (appr. 16cm in real)
and the shown eyebolt has appr. the same size (appr. 15cm in real)
I am using for these rings and eyebolts these on, which I have in stock - rings with 2,5mm outer diameter (12 cm)
and the eyebolts with inner diameter 1,37mm and outer diameter of 1,93mm (9,2 cm in real)
so definitely my eyebolts are already smaller than the given information from Goodwin
The smallest eyebolts I have in my "collection" are from Caldercraft with 1,3mm (6,2cm in real) but they are looking already very small, so I do not use them for this case
Here some short comparison of the model eyebolts and the Goodwin drawing - at the end often it is a question of taste - but maybe I have to check once more the possibility with the smaller 1,3mm Caldercraft eyebolt and the 2,5mm ring
mine are smaller than the Goodwin
Is the eyebolt an eyebolt? Or a square hook?
At A the ring is lying to the side and at B in the middle. With an eyebolt it is lying always in the middle.
When it is an eyebolt it is always very small, just like an iron bar with a hole in it where the ring goes through.
Or how I did it, I believe this method comes from Bibligon.
Like the eyebolt on the gunport-lids?
I have to check once more the individual drawings in the Anatomy book, if these are such one, or square hooks - or only a mistake in the drawing
Witaj
Wszystko wygląda pięknie Uwe dodałeś tyle szczegółów więc warto by zrobić kółkowanie ale to jest tylko moja sugestia a ty idz swoją drogą. Pozdrawiam Mirek
Witaj
All of Uwe's comments were taken with great enthusiasm, rather than with a rude expression, but it is only my suggestion that you take your own drugs. Regards Mirek
Many Many Thanks to all of you for the comments and hints - these information are helping me (and others) to make step by step the model(s) better and raise the quality with sharing knowledge and also opinions.
I have sometimes the problem, that I try to build my model as much as possible following the drawings and sketches shown in Goodwins Anatomy book (f.e. the same planking pattern of the deck) - but sometimes there are errors shown....
For some actual overview here some more photos - for the moment I will keep these eyebolts like they are (according Goodwin ;) ) but maybe later on I will change them
and the complete upper part of the model
Many Thanks for your interest - keep on with commenting - please
That’s looking very nice, Uwe. With nice color contrasts on the deck with those covers.
Uwe, great job.
Still, consider changing the eyebolts. Not against the background of the same ones near the gun; on the cover they do not seem natural
Once again, a lot of catching up to do, great result, Uwe.
There were a lot of questions and answers about nails, eyelets, color scheme, decoration, etc. I don't know what to say, it looks brilliant. Don't put yourself under pressure because of the meeting in October, believe me Uwe, I'm sure I won't reach the construction stage I'd like with Le Rochefort, so no more pressure. There's strength in calmness.
