Thanks TobiasHi Dave a great result, little La Nina looks fantastic, keep up the good work.
Привіт! Дякую за зауваженняПривіт. Як для першої моделі виглядає чудово! Як на мене, то я б замінив білі нитки на щось більш темніше і трьохстрендове. Ну то вже в наступній моделі
Hello. As for the first model, it looks great! As for me, I would replace the white threads with something darker and three-stranded. Well, already in the next model![]()
Good evening Grant. Thank you very much for your words!Good evening Dave. What they all say…. She deserves all the accolades given- beautiful. Cheers Grant
Daniel, thanks for stopping byHi Dave, I'm just now getting to see your beautiful LaNina. I especially like her hull! You are a natural at this hobby. By the way at your suggestion, I am enjoying Jack London's 'The Sea-Wolf', wow tough times for tough men!
Tobias, even if I managed to sew more or less tolerable sails, then all the more you can get a decent result, I’m sure of it. Why, I suspect that with your care and precision, your future sails will be much better than mine, which, by the way, are far from ideal - for example, pay attention to the luff of each sail - despite my efforts, they turned out poorly.They are very beautiful sails, I hope that one day I will be able to sew sails that are even remotely as beautiful as this since I have zero experience and have never worked with a sewing machine.
Thanks Daniel. Yes, I couldn’t avoid puckering between the seams, unfortunately. This may be because the sewing machine is not set up correctly. Or I don't have much experience. But sewing without puckering is quite possible - for example, the sails that Oleg Sergin sewed for another modeler (Oleg, by the way, sews sails to order).Dave your sails look just fine. I think sails are perhaps the hardest item on a model to produce. For one thing they just don't lend themselves to being scaled down properly. Puckering is a problem most everyone has to deal with because of the sewing pressure required on all the seams and the bolt rope is really tough to attach.
To avoid wrinkles, you need to put paper under the fabric. Then carefully remove itThanks Daniel. Yes, I couldn’t avoid puckering between the seams, unfortunately. This may be because the sewing machine is not set up correctly. Or I don't have much experience. But sewing without puckering is quite possible - for example, the sails that Oleg Sergin sewed for another modeler (Oleg, by the way, sews sails to order).View attachment 459416View attachment 459417
Thanks for the tip)To avoid wrinkles, you need to put paper under the fabric. Then carefully remove it
Way to go Dave. Lovely sails. I agree the stain came out perfectly and will look so good on your ship. Cheers GrantThe sails are readyView attachment 459292View attachment 459293View attachment 459294View attachment 459296View attachment 459295View attachment 459291View attachment 459297I tinted them with very strong coffee, which is why they have such a dark color. I did this on purpose, with the expectation that over time they would fade and become lighter. But if this doesn’t happen, I won’t be upset - I like this color too![]()
