Sorry, hit the post button above before finishing this post.I dispense with the usual system of identifying the bends using letters or symbols because doing so is cumbersome for a ship with as many bends as the Sovereign had.
You are right, the effect on construction would have been small. However, these small numbers had a massive effect on the mathematics behind computing the rising and narrowing lines. Incorporating tractions are decimals really slowed things down. For example, the steps used to multiply two numbers together were different, and more cumbersome than the steps we now use (see, for example https://www.emmaths.com.au/blog/a-b...he 17th century, the,every digit in the other). Shipwrights rounded numbers to speed things up, and to avoid the errors inherent in performing such a task. Multiplication was so tedious that John Napier "invented" logarithms in the early 17th century to help speed it up. In his words, multiplication required a “tedious expenditure of time” and was subject to “slippery errors."ok, I think we mean the same thing.
However, these minimal deviations have no significance in real construction
I see that it is time for me to read the treatise again.You are right, the effect on construction would have been small. However, these small numbers had a massive effect on the mathematics behind computing the rising and narrowing lines. Incorporating tractions are decimals really slowed things down. For example, the steps used to multiply two numbers together were different, and more cumbersome than the steps we now use (see, for example https://www.emmaths.com.au/blog/a-brief-history-of-multiplication-algorithms#:~:text=In the 17th century, the,every digit in the other). Shipwrights rounded numbers to speed things up, and to avoid the errors inherent in performing such a task. Multiplication was so tedious that John Napier "invented" logarithms in the early 17th century to help speed it up. In his words, multiplication required a “tedious expenditure of time” and was subject to “slippery errors."
Hardly. This level of in depth research, including comparisons to the research information of others, is usually unavailable to the average modeler when it's applicable to specific ship.Aha! So you're the one that's interested. I have the feeling that all of this documentation is putting everyone else to sleep, but I thank you very much.
