I think those things are called "bollards".
**VIEW THREAD HERE** |
…… I stole some of Justin’s throttle grip wire (0.4mm) from his motocross tool box. Hey he won’t let me buy anything so it feels like sweet revenge.
Great restoration GrantGood morning Peter. Thank you kindly. I amazed myself. It has almost been more fun working out how to make the wood than building the ship…..
Good morning Johan. The dead eyes are easy- I just 3D designed and printed them. As these will be black I just paint them.
The blocks and ropes I have the kit version from the Victory and Xebec. They are typical kit ropes and blocks. Hmmmm??
View attachment 466818View attachment 466819
I also have some supplies of the “good stuff” from Dry dock Models however I’m not sure the scale will work on my Bounty. Definitely short supply tho.
Last resort will be to eat humble pie and concede and buy some more of the good stuff
Cheers Grant
In the running for funniest post of 2024. Good luck Roger.“Bollards” - That’s the word I use when someone takes things out of my tool box too.
Good morning Peter. Thanks. I have struggle with the tiny hooks and blocks. I think I should have used 2.5mm blocks but don't have any. As for those hooks, I just made them as small as I could and look more like wire bent into a "S" than hooks. Looks OK tho, unless you view under a microscope.A good start of ‘the rigging proces’ with nice tiny iron work, Grant. And ……. The wires is not stolen ……. He forced you …..
Roger and roger. Thankfully only 4 cannons on the BountyRoger that.
Good morning Ron. Thank you for the compliment and having a look at my renovation. In many situations my ambition has exceeded my talent, however I then just go for more of a representation than an actual replication. Been super fun tho.....and it continues.Grant,
I just went back to where you started on this project and must say, marvelous work! A project not many could pull off as you have. (Or had the nerve to attempt)
Good morning Jim. Thanks for the compliment. Yep canon rigging.......enough said... quickly raised - does not considered fallenGreat job (as always), rigging is not my favorite, dito!
Thanks Don.I think those things are called "bollards".
Good morning Roger. Im with Paul......Brilliant wit....so funny.In the running for funniest post of 2024. Good luck Roger.
Thank you very much indeed. This is so cool. I generally only attempt to print metal parts if needed, however I may not get my leftover kit blocks looking good so this is an awesome alternative.Great restoration Grant
If you don't mind printing blocks from resin here you have a set just to adjust
Maritime rigging bundle | 3D Print Model
Model available for download in Stereolithography format. Visit CGTrader and browse more than 1 million 3D models, including 3D print and real-time assetswww.cgtrader.com![]()
Model ship rigging fittings for resin printing | 3D Print Model
Model available for download in OBJ format. Visit CGTrader and browse more than 1 million 3D models, including 3D print and real-time assetswww.cgtrader.com
You could consider emptying the roll except for ten centimeter, and put the roll back where you found it.Although I have a feeling Justin may use a stronger term when he next looks for his grip wire;
I like the way you think PeterYou could consider emptying the roll except for ten centimeter, and put the roll back where you found it.
Canon is looking great bye the way
Thank you kindly Uwek.Bravo - ver yclean and accurate work -> very good
Nice details on the rope work of the canons and on the iron work on the pumps, Grant. It’s ‘Bounty worthy’.Good morning.
Got a second cannon rigged…whew.
View attachment 471004View attachment 471005View attachment 471007
While playing with fiddly bits I decided to complete the brass on my pumps and fit them:
View attachment 471009View attachment 471010View attachment 471011
Cheers Grant
Looking really good over all Grant. The belaying pins and the blocks on the guns with frapped lines look especially nice.
Lovely work, Grant. The cannon rigging is very tidy - and you know I like tidy...
Stunning work Grant.
Back in my RC aircraft days some guys would rebuild after unintentional landings. I was never one to rebuild. I would 'dispose' of mine.
You're setting the bar pretty high for restoring.
Good morning Gentlemen. Thank you kindly for your comments. It is always a source of encouragement and valued indeed.Grant,
awesome pumps - super detailed indeed- cannon rigging has also always been your forté ---
Regards,
Good afternoon Roger. Thank you. I agree however in my case it is more of - I’m not very good at making coils and this is the lazy option. How are your stunning carronades coming on? Cheers GrantYour fine work continues Grant. I really like the look and how you rigged the cannons. Securing the tackle the way you show in your photos is, to me, a more realistic and practical approach than little coils deployed on deck.
