Fantastic small scale modeling!
Thanks Paul, you are very generous with your support, not only for myself but many others on this site too.
Good afternoon Roger. Marvellous detail- so tiny. Are those 2mm hooks? At 1:64 it must have been difficult getting the scale right but you are owning it. Kudos. Cheers GrantOctober is nearly over so definitely time for an overdue update. I spent a lot of time working out how I was going to pre-rig the breeching rope and tackle for the carronades. At 1:64 I struggled with the tiny ropework but reached a solution that works for me.
A single photo showing the protracted progress so far, including practice runs. Paul @dockattner was correct calling it “purgatory”, which tells me where the word “whipping” comes from.
that`s a great idea rigging the caronades before placing them. I am a wimp in that I just installed the breech ropes. I like the hooks too. DId you blacken them yourself, or did you buy them like that? or did they come with the kit. I can't remember if the hooks were supplied or not.October is nearly over so definitely time for an overdue update. I spent a lot of time working out how I was going to pre-rig the breeching rope and tackle for the carronades. At 1:64 I struggled with the tiny ropework but reached a solution that works for me.
Breechings
The breechings are now pre-rigged. Both tail ends have a single whipping and the bights are seized in two places. Once the first end bight was completed I passed the other end through the carronade and sled carriage breech rings before forming the seized bight at the other end. I have to do a little clean up, continue pre-rigging the eye bolts and rings to the bights then it’s the tackle.
My thanks for all the continued support, likes, comments, observations and questions.
Same scale as mine. Infinitely better rigging. Nice.
that was as far as I had gotten with the carronade rigging on my Brig Syren, but your cannon rigging looks way better than mine did. Now I have to contend with the cannons on the Constitution. I say I am going to try fully rigging them, but I may change my mind. I think I'll do a test one to see how it looks and if I like it, then I'll do the other ones. My biggest concern right now is the size of the rigging blocks and whether they are too big for the cannons.
Good evening Roger. I’m with you the brass hooks look way better in the photo. Man those sets of cannons look amazing and personally I would have some frustration to use the brass hooks. Cheers GrantHi Grant, the hooks shown are from two different sources. The photo-etch ones on the left are 3.75mm from Dry Dock Models. On the right side of my photo are three sizes from Syren Ship Model, they are plastic. I blackened the brass ones. Early stages for me but I prefer the brass ones over the plastic ones. However, the plastic ones are slightly easier to handle and seem to hold to an eye bolt ring a bit better. At 1:64 scale I think I’m going to use the Dry Dock ones. Depends on my frustration level.
Yes it is Jack. I purchased pear billets and cut down to scale.Is your deck made of pearwood?
that is the best way to get a colored deck instead of trying to stain basswood like I did. My next ship uses pearwood too. Should be niceYes it is Jack. I purchased pear billets and cut down to scale.
i like the effect you got by doing that.I think you’ll enjoy a pear deck. I cut the planks then tossed them in the air (sort of) to randomize them as I picked for final cutting and placement. Gave me a deck of varying shades of the pear wood.
my problem was that i was trying to be too cute. I failed to follow the KISS principle. anyways i am still plugging away at my deck. should be done soon.Thank you Jack.
