It’s a thing of beauty, Smithy, and I award you full points for correctly using the word brobdingnagian in your discussion of your liliputian vessel.
Photographing the whole thing makes my autofocusing camera scream and beg for mercy
Oops. The bunting tosser is going to be embarrassed when he tries to raise the ensign. It wasn’t a mistake, honest. It was a practical joke played by the riggers on the signalller.
The instructions for rigging are beautifully clear. Tie a line, cross it off, tie another, cross your eyes, make a cup of tea…
I never thought I’d need these Brobdingnagian tweezers but they were invaluable at one point. I’d dropped a block and it rolled under the desk.
Photographing the whole thing makes my autofocusing camera scream and beg for mercy.
It’s beginning to look very complicated. A viewer could be forgiven for thinking that this is difficult to do. In fact, if you can thread a needle, tie your shoelaces and follow a diagram, it’s a piece of cake, er, several pieces of cake. Fair enough, it’s a bakery, but that just means there are lots of pieces of cake. None of this is difficult, even for my clumsy fingers, the effect of complexity is achieved merely by repetition. Many easy things do not add up to a difficult thing.
Work of art? If a knitted sock is a work of art then so is my model.
Nevertheless, though the doing is a bit of a chore, I’m liking the result.
One idea would be to soak a long length of thread with PVA glue and then suspend it between two supports (e.g: two chair backs) allowing enough slack to get the rough curve you want. Once the glue dries, you cut it to the length you need for the run between the blocks (or however it is supported)but it should still hold it’s curve if treated gently. Would need to dress up the ends to make it appear that it’s actually longer than it is, but that should be easy enough. Did I describe that well enough to make sense?All of my rigging lines are both too light and too stiff to take up that shape naturally. Pulling them tight into straight lines is, of course, an option but is there a way to make nice smooth curves through the air like that?
Smithy, I think your Alert looks great!
The drawing you showed for the sheet and clew rigging caught my eye. This is not in any way a criticism, but more of a question for anyone with more nautical knowledge than I. I was curious about the dearth of lines on the drawing. Is there another rigging plan with more sheets and clews, or is this kind of a way for Vanguard to keep the kit costs lower by not supplying as many blocks and line. First, (and I could be wrong here, please correct me), I've never seen a sheet rigged two yards below it's respective sail as the topsail sheet is in your drawing. I have always seen them rigged to the yard directly below the sail. And while there is a sheet for the to'gallant sail, there is no clew line. Not to mention that there is nothing at all for the two lower yards.
I have seen models without sails where any running rigging relating to the sails was stripped, but I've not seen one to my knowledge where it was kind of half and half. Just curious. Keep up the great work Smithy!
Dumb and DumberAlas, my loyal penpal (and it’s really creepy what autocorrect makes of that word), in poison you would discover that I am as dull as a trainspotter’s anorak, with all the memorable charisma of… I'm trying to think, what was his name? You know in that one movie, the one that's like the other one but not as good? No, the other guy, the really boring one...
For nowGuitar practice also makes my back and arms ache Cat
PreachFor now![]()
It’s all very strange. EDIT. Hold on a minute those sails CAN’T overlap. They would have to pass through each other to reach their respective yards. How bizarre. They must’ve used either the topsail or the squaresail depending on conditions.
Judging you from your question, you are more qualified than I to comment on the clews, tacks and sheets for this unusual arrangement of sails. Do you think it’s plausible? I’m following it because of its clarity rather than for accuracy but I’d be interested in your opinion.
Alcohol: no effect
I am not, by any stretch of the imagination, more qualified. I merely have a love of sailing ships of yore and enjoy learning all I can about them.
On my drive home from work, I was thinking about that whole configuration and how it might work. I then realized that I had never heard of a "spreadsail". Studding sails? Yes. Spreadsail? No clue. The ONLY hit I got from G00gle was from a stamp website:
G00gle's AI (asinine intelligence) came back with a response like it knew what it was talking about, but following the resource link, it was quoting a paragraph about spritsails. It also appears from your plans, that the "spreadsail" yard was only used to reef the topsail and didn't carry any canvas of its own.
So that said, I think you are probably right in that they would use one or the other depending upon conditions. Perhaps just for maneuvering. With all the area on the staysail, jib and mainsail, the topsail may have seldom been used.
I found this image of her on SOS (cited as from a museum) ... and it's ... just wrong.
