I'm very glad to hear it, thank you. I thought the first pancakes are always lumpy))) I always want it to be absolutely perfect, but it takes a lot of time and you understand that the result that is - is enough))Wonderful joints. I like the result
Thank you)) I hope I motivate you to start your own Alert ? )))Really precise job.![]()
I'am working on my Fly-project. There is so many work, that I do not find time to build on my Alert.Thank you)) I hope I motivate you to start your own Alert ? )))
Hi, nice work, congratulations, I ask: did you do the nailing of the patches? Thanks. FrankSo, in the last post I showed how I made the frames of the front part of the hull. Today I will show how I assembled the frames of the rear part.
In general, everything is very similar, but I did some things a little differently, so I will show you in detail again.
Spoiler: some of the rear frames had to be redone, because (if you remember, I showed this) there were defective parts and they had to be redone, but I will tell you about this in the next post, but for now...
Assembly and adjustment, as with the front frames, was carried out in special templates, which is very convenient. With experience, all manipulations become faster and more accurate.
Then, all the parts are taken out, a film is laid and they are assembled back, but with glue!
To prevent the glue from opening the glue seam when drying, I apply a strip of glue over the seam. Then, after drying, I take out the glued frames again and remove the film, check the joints and the accuracy of the glued parts. (In the next post, I will tell you how to fix it if the parts are glued incorrectly, with an offset).
Then I cut off the excess glue with a sharp knife to make it easier to polish, because this glue is very strong and sandpaper cannot cope with it, but we get stuck in it.
It takes a couple of minutes, but then it saves a lot of time and simplifies the polishing process.
I polish with 240 grit sandpaper.
I like it when the joints are so thin and the glue seam looks like a cut =))
Then, to polish the back side, I turn the template over...
... and I push it so that the frames stick out. This method (compared to how I did it at the beginning) saves a lot of time, since you don't need to take out the frames and you don't need to insert them from the back side, where they usually get jammed and don't want to stick in, since the laser cut on the back side is slightly smaller by microns than on the front.
Well, after that, all that remains is to polish the back side and go lightly along the ends, removing excess glue, and the micro-steps and frames are ready for contouring!
So far I really like the pace... let's move on!
Hi. Thank you. I haven't done the bolt imitation yet, I will do it after the contouring. I will only do the imitation, I understand that there simply won't be enough time for brass or wooden fonts. I will talk about this later.Hi, nice work, congratulations, I ask: did you do the nailing of the patches? Thanks. Frank
Thank you for your words. I am also often lazy and do not always do as I would like, but this is all my laziness))) But in this project I want to make at least a decent result. Now I am making the middle frames, of which there are 41 pieces and they are of two shapes. That is, 20 + 21 identical frames with 7 parts in each... and what is most important, today I managed to make only 8 halves)))) I feel this will last a long time))It's good to see how much effort you make to clean and polish the wood. Something I often miss a lot. I always find it a shame when you see the fibres, no surface treatment, no oil and I have to ask myself why you have to work so hastily.
Dirk
Thank you. Yes, it is not a fast process, but I am gradually moving forward. The dimensions are approximately 5 mm.You continue to create beautifully made joints.I realize you will have a lot of fairing to do later, but wondered what is the approximate moulded dimension at the top of the top timbers as they are in your photo.
Thanks
Wow, that is a lot of wood to remove if you are going to fair it to the thickness on the actual vessel.The dimensions are approximately 5 mm.
Definitely, I think so too.Much better without the white wood!
Dirk
Since this is a kit, the sides are a little thicker here and definitely not 2.5 mm. In theory it should be 4.5 or 4,2, but I plan to make it a little thinner, maybe 3,7-3.5 mm, since anything less will be very fragile.Wow, that is a lot of sanding you will need to get to the approximate 2.5mm it would be at your scale of 1:48. (dimension from Steel and The Builder's Repository 1788) Having it heavier though makes it stronger and less prone to breakage while doing the assembly but then the fairing to take away half the wood is going to be long and arduous. At least we get to pick our poison in these situations.
The problem with leaving the top timbers too thick is that when you add the planking inboard and outboard, the top rail will have to be much too broad. I agree these can be fragile, but I found that I can add a temporary batten to the outside of the framed model, then sand the inboard side so all is in alignment. After that, add the spirketing inboard then remove the temporary batten on the outside and finish fairing the outside to the thickness required. In this case it would be about 4 inches to 5 inches (about 2.5mm) If you are not comfortable with getting it to the scaled thickness and leave it heavy I totally understand.In theory it should be 4.5 or 4,2, but I plan to make it a little thinner, maybe 3,7-3.5 mm
I will try to stick to the anatomy of this ship during the construction process. I printed it out in full size and will take measurements while working with the finished hull. But while the assembly is in progress on the slipway, I will stick to the instructions from the kit, otherwise I may not assemble it correctly. I will definitely make the top timbers and railings thinner, since they are very wide in the kit, but this will happen later.The problem with leaving the top timbers too thick is that when you add the planking inboard and outboard, the top rail will have to be much too broad. I agree these can be fragile, but I found that I can add a temporary batten to the outside of the framed model, then sand the inboard side so all is in alignment. After that, add the spirketing inboard then remove the temporary batten on the outside and finish fairing the outside to the thickness required. In this case it would be about 4 inches to 5 inches (about 2.5mm) If you are not comfortable with getting it to the scaled thickness and leave it heavy I totally understand.
Alaln
But they look so good, you should be happy.. So another 8 days of monotonous repetitive work awaits me... eh... let's go
Thank you for your words, I am very pleased to read this. I, in turn, spent a lot of time on forums studying different methods and techniques of production and for this reason I created the site to concentrate in one place all the most interesting things without unnecessary information. And I am always grateful to those who describe the whole process in detail. And I learned a lot from this, so I try to do everything the same way myself. and I am very glad that this will be useful to someone.But they look so good, you should be happy.I would bet seeing this great array of photos and how well these frames are "shaping up" is giving a lot of members a goal to shoot for.
