Roter Löwe 1597 by Ondras71 - scala 1/60
Thank you very much Chuck, thank you for the like.
More small blocks made..
Before I have the milling cutters ready for the production of small pulleys, I started making all the ropes. There are a lot of them, 10 basic diameters in total. All Dutch ropes are right-handed, which means that it is difficult to make weak 3x1 ropes. Right-handed threads are first twisted into left-handed threads and then the ropes are knitted. Guttermann threads are quite good, but the weaker cotton waxed Sajou threads like to hold their shape and I don't want to twist them in the opposite direction. After a long time of trying, I figured out the ropewalk settings and especially the last adjustment. All the finished ropes are slightly hairy, I stretch them under the flame of a lighter.. Explosion
The 3x1 Sajou cable with a thickness of 0.35 mm also has to be pulled over the edge repeatedly to align the threads. But it works..Sleep
Nice ropes Ondras, you aware of heating up Gütermann or polyester rope to keep te rope in shape after you made it?
And ofcourse Happy birthday.
Thank you Stephan.
I only use cotton threads, it certainly doesn't make sense to heat them.
I tried to patina the ropes, but the cotton absorbs the paint and the result is bad.
Another disadvantage of cotton threads is that they cannot be used to weave very weak ropes..Cautious
Thank you all so much for the birthday wishes, but there's nothing left to celebrate...;):D
Thank you Stephan.
Better use polyester yarn to make rope. You can colour that with Judea bitume like Mat did on his Papegojan. A real good looking result.
The only thing with polyester rope is that it will unravel when you cut it, but that's why you bake it short in a oven.
Post in thread 'Pinnace Papegojan 1627 - 1/48 [COMPLETED BUILD]' https://shipsofscale.com/sosforums/...an-1627-1-48-completed-build.7055/post-160824
Post in thread 'Make your rope on a rope walk' https://shipsofscale.com/sosforums/threads/make-your-rope-on-a-rope-walk.9094/post-219002
Hello Stephan. I have studied both of these fibers, Mati's ropes are the best for Papegojan. I have bitumen at home, but it doesn't work on cotton ropes, the ropes soak up like a sponge.
I'm thinking about synthetic ropes, especially after I saw situations at competitions how cotton ropes react to air humidity. In a dry place they loosen and sag, in a humid place, especially in Burgas by the sea, they stretch like a string until they bend a log.. I couldn't believe it..o_O
Glad you think about synthetic ropes. For example, with Gütermann Skala 360 you can make very small diameter ropes, like 0,2 mm. With cotton almost impossible. And your right about that cotton reacts to humidity. Synthetic too, but it's so minor you can't see the effect. Another advantage is that it last much longer on your ship. Cotton will break apart in time. I use Gütermann Skala, Mara and Amann Serafil.
And your servingtool looks real good.
I am familiar with the Rope wrapping machine. I must confirm that the author Roman from Poland has mastered it with great craftsmanship. Super gears with gentle resistance prevent untangling. Polished material brass and aluminum. Interchangeable parts for many different activities. Very pleasant work.. Thumbsup
I wrap weaker ropes directly, strong ropes filled with thread..
Fixed rigging ropes braided...
Other work halter shrouds, eyes and Stay Mouse basics..
Dirt from superglue patinas well with brown bitumen..
Now I'm going to braid Stays Mouse. I found this work 1:1 on Duyfken replica..Explosion
Znam maszynę do owijania lin. Muszę potwierdzić, że autor Roman z Polski opanował ją z wielkim kunsztem. Super koła zębate z delikatnym oporem zapobiegają rozplątywaniu. Polerowany materiał mosiądz i aluminium. Wymienne części do wielu różnych czynności. Bardzo przyjemna praca.Kciuk w górę
Słabsze liny owijam bezpośrednio, mocniejsze zaś wypełniam nicią.
Stałe liny olinowania plecione...
Inne prace: osłony kantarów, oczy i podstawowe akcesoria Stay Mouse.
Brud z superglue dobrze patynuje się z brązowym bitumem.
Teraz zaplatam Stays Mouse. Znalazłem tę pracę 1:1 na replice Duyfken..Eksplozja
Witaj
Mam też owijarkę od Romana super sprzęt , robi również maszynki do robienia lin też są bardzo dobre. Super praca Ondras . Pozdrawiam Mirek
Thank you very much Stefan and Mirek. Thanks for the like.;)
I studied the Stays Mouse braiding system. I created a jig from scraps. I used two systems I found..Thumbsup
The ends are tied on a rope wrapping machine. I gradually weaken the wrapping thread until it is gone..Okay
Stays mouse on Main stay done..Explosion
