Kurt Konrath
Kurt Konrath
Great looking model and nice to see the lighting for lower decks to show when complete.
Not a big fan to be honest as it gives little leeway for anything slightly out of line/ squareMore excellent progress Alan and now I see the beam I mentioned to be cut away. What are your thoughts on the finger join approach AL have opted for the front to back decks?
Think there’s a couple on facebook “HMS Victory Modellers site. Including mineI have been anxious to find someone building this kit. Thank you for posting. Are you aware of any other build logs?
Hi TonyJust watched video 69 posted yesterday, rigging scares me somewhat!
I'm using CA glue to attach my 1st planks to the San Fran just wondering what you are using. Yes I see from your pic temp attaching the Beak is a good idea!
Regards
Tony
Glad to help Alan. As you have The Anatomy of Nelson's Ships you have a great reference to compare with the kit. That book was my first meaningful book for our hobby, going back 50 years now and I still go back to it after all these years.Thanks for your observation
Hi Alan
I note that on the instruction video #14 at about 4.50 the wiring on beam B14 does not travel through the whole beam it is re-routed around the adjacent curved back wall. I though this maybe to accommodate another light in that area but it does nor appear to. Any idea why this is done that way?
Regards
Tony
Hello.Instructions video 3 completed
Hi,Hello.
What glue/process did you use to make up the boards for cutting the hold parts out of? I am using the same glue as AL uses in the video and they keep breaking whilst I am trying to cut the patterns out (doesn't help the wood seems really difficult to cut even with a swann morton blade). I tried an alternative by making the boards using diluted PVA but that was even weaker.
Thanks. I checked the post and yeh that seems a better way of doing it. I did try to find some 1 or 1.3 and then use some veneer strips for the planking but could only find 1.5mm.Hi,
Yeah I had the same problem, I persevered for vid 3 by re-gluing after they came apart but changed tac for videos 4&5 (check out further in thread), as there are far more pieces to cut, by getting 1.5mm sheet and cutting the shapes from that, then scribing the planking
Regards
Alan
