Super detailing Peter, very impressed, If I can't see things from 30cm away I have the tendency to skip and 0.3mm dowels would never happen!
Thanks, Dom. That's actually the case with me too, but with clip-on glasses the scale becomes ‘sliding’. And luckily the Byrnes Drawplate has no smaller holes……:rolleyes:
Started working on the hatches. In addition to the technical drawing shown above, the Amsterdam restoration book also contains some old photos. The hatches are sometimes slightly raised.
They are also slightly raised in the model that Sybe de Jong made prior to the restoration:
I estimate that Sybe's model was built on a scale of 1:25.
First I made a test hatch entirely by hand. Based on that I was able to mill some details:
(Unfortunately not completely sharp with the iPhone.) The test is on the right and version 2.0 on the left. The hatch is 15.75 x 13.5 mm and 1 mm thick. The recessed rounding of 2 ø mm is 0.5 mm deep. The ring is recessed in it:
That can be seen in one of the details on the drawing. The eye of the eye bolt is also slightly recessed.
This is the result:
Made the 1,2 ø mm eye bolt and 2 ø mm ring from 0.4 ø mm iron wire.
Also with dowels for the connection with the clamps on the bottom:
With in the middle the clamp with hole for the lashing of the hatch.
Because you can look into it from the side, I will also secure some hatches with a rope later.
8 more hatches to go .......
This is the result:
Made the 1 ø mm eye bolt and 2 ø mm ring from 0.4 ø mm iron wire.
Good afternoon Peter. I should be used to you building details that small but I’m still amazed at what you do. Kudos. It’s not the fact you add these tiny details it’s the accuracy of the details within the details which impresses. Legendary.
Remind me not to buy those clip on glasses…. ROTF
Cheers Grant
Cheers Grant
Thanks, Grant. The detailed drawing are part of the problem of adding details or not. ;) What you can’t see on those drawings you don’t have to make. :) But that’s also the advantage of scratch building.
Then it’s just a matter of ‘to clip or not to clip’.
Will you be cutting the frame work in two, attaching the two halves to either side of the hull, or wil the entire frame be attached to either the left- or the right side,allowing you to keep the hatches in place?
No more cuttings, Johan. As show here it will be placed on the port side:
On starboard just the stringer plates.
Making the hatches in several steps:
-sanded, milled and drilled;
-doweled and ironwork made;
-top side completed;
-bottom with clamps and lashing rope.
As it should be on the deck:
The hatches have had one layer of linseed oil. Then the dowels also come out a bit more.
The frame has no oil yet. I have to glue deck planks to the sides later.
From the inside:
I can attach the lashing ropes to the beams later. Then I can't lose them either ..... ;)
How did they do that in real life? Once lashed, how do you get out of the hold? That is worth asking some old fishermen ......... :rolleyes:
Fantastic presentation, Peter. I love the recessed rings!
Thanks, Paul.
I had a bit of a reverse order of making. First the size of the recess and then the rings made to fit in there.
'Little buggers', put the rings through the eye bolt and then squeeze them shut. Almost impossible to hold.
First of all, Happy (way) belated Birthday Peter! Your work is still unparalleled. Tree type nails as plugs looks the best to me too. You know to me the black caulking on the deck boards of the real ship looks fantastic I think because of the sun weathered grayed deck boards. It must make the contrast look more natural than when compared to the Bluenose II's more modern planking with black on cherry brown wood.
Thanks, Daniel. Always time for a after party.
A polished deck like the BN or a weathered deck like the Balder make a big difference in appearance in combination with the black caulking. I make the deck from the same wood as the hatches. The intended gray for the caulking will then be a nice intermediate solution.
The first strokes will be placed as a second and more definite test.
