Marvel's Hydra Coupe 1/12 scale full scratch build
Finish it, cover up all the work, but then make a mount for it that holds it at 45º and put a mirror under it so people can see the details underneath. Maybe remove one side of the hood.
I post on 3 different forums and explained on all 3 my conundrum. I received plenty on interesting ideas l. But there's one that I think will be best. It's rtwpsom2's. I'll but the body on the rolling chassis but I'll modify one of the front lower panels to give a good view of the motor and all the bits and pieces that are worth seeing, probably on the steering column side. The underside of the model could be seen by reflexion on a mirored floor. I can also raise the hoods to give an even better view. I slightly modified the body to be able to lift it from the frame if need be. With this solution, I get the best of both worlds, a good view of the fun moving stuff and the great looks of the body on the frame with the wheels and all the trimming. I'll post a pictures of the 3d model showing all this soon.
It really is quite amazing. I do agree that you can't hide all that stuff.
Perhaps next you should build one of the Titanic's engines. I think those huge ship engines were quite something. I saw one really nice model at a museum in Halifax a few years ago, all made in brass, and with a couple of people standing beside it, to show the scale. A working model of one of those engines would be pretty cool.
A 1:12 version would stand some 30" high!
Thank you everyone for your positive comments and insights.
So here's the 3d model showing the modified left front body panel that give a good view of the engine.
And when seen from the other side
Have you decided what is going to go in those storage boxes under the front fenders? Considering the size of the car, they can have four or five attack robots in there. I am not really up on the Marvel-verse, but there is probably some unholy creation that can fit in there.
Cheers,
Rick
The body is slowly being printed. The rear end is quite big to print, even in 2 halves. My first try didn't work. But still, it's starting to look like something a vilain would drive.
First rear end half print, close but no cigar. It's as if the max printing volume the slicing program gives me is incorrect, the top of the part didn't print (circled in red). It took over 12 hrs to print and 500 ml of resin, oh well...
But still, it's getting there
For those wondering where this gadget is going
All major body components are printed. I had another issue with a rear body half ( problem with the U shaped cutout for the bumper) but this time I was able to repair it. I printed a patch and replaced the section. Still needs a bit of putty but it should be ok. Also printed a test door, the outter sheet is too thin. I'll have to thicken it a bit. I decided to print the outter sheet and inner panel as a unit. Once painted, I'll be able to apply the leather. Speaking of leather, I found a piece of nice thin brown leather that should look pretty good (thanks Rick).
Rear end repair
And once repaired
Test door
Door hinge insert
And so far
The brown leather
I ordered a roll of that amazing tape I discovered. I used a bit on the start of the seats for the Bugatti, and it's really good. You'll have to try it. It's called Speedtape and it's available in Canada from Grainger. You can look it up on their website as FILM TAPE, DOUBLE-SIDED, TRANSPARENT, 1 IN X 16 ¾ YD, 5.5 MIL THICK, ACRYLIC, INDOOR.
Cheers,
Rick
I find it really interesting to see how many times you redesign and reprint something. This goes to all those millions of parts out there that one can buy and download for next to nothing. I have always said that the design is the thing, and all this work really proves the point. It is no wonder that sites like Shapeways eventually fail; 99% of what they sell just isn't good enough, even at a price of $0. Even if Shapeways is resurrected in some form or other, sites like that, and dozens of others, really need to have a system where designs are checked, double-checked, and tested, before they are allowed to be sold to the public. I honestly wish I had the time to design such a site. Perhaps when I "retire", whatever that means.
It's update time. I started gluing up tge body together. First is the rear two halves. I installed some fish plates to better align the two halves and to get more gluing surface. It came out good, is rock solid and very well aligned. I'll need to do a bit of epoxy putty on the seams and gaps but I think it should look pretty good. Both door hinges are glued in and I even added some rivets to the only fish plate that will be visible (with the trunk lid opened). I also printed the trunk lid but it's not to my liking, I added some longitudinal stiffeners to the new one that should help to better maintain the shape. But even with it not being perfect, it still looks good.
Two halves glued together with white styrene fish plates in place
Riveted fish plate
Hinges installed
Test fitting of the bleu cube thingy which fits as planned
test fitting of not perfect trunk lid
captain america's shield cameo
And a few general pictures
