- Oct 1, 2023
**VIEW THREAD HERE** |
I believe they were 8 poundersAssuming her armament was all 32 pounder Carronades, based on the drawing from Dupin the running tackle blocks were likely about 6" long. The rope would be about 2" circumference and the breech rope would be about 5 inch circumference. There is good information on tackle for long guns, but I have never been able to find definitive data on Carronade rigging. If anyone can share a source on this information that would be great. I could not find info in Falconer, Dupin, or elsewhere in other than drawings, so far.
Thanks
I saw something similar on Olha Batcherov's recent video. Interesting but beyond my abilitiesInteresting that the eyebolt and ring bolt go all the way through the bulwark; something I’ve always tried to avoid doing on my models.
Drilled theView attachment 517092 holes in the cats heads and assembled the bumpkins.
I can't seem to get accurate spacing. Need an x,y table
I just looked at photos of a dozen contemporary models at Preble Hall in Annapolis and not one shows the bolts coming out the outer planking so we are not alone in not having them come through the hull of our models. In full size construction, it makes sense to have more than just an eyebolt without something to secure it, but for a model?????Interesting that the eyebolt and ring bolt go all the way through the bulwark; something I’ve always tried to avoid doing on my models.
If you use copper instead of brass, a touch of diluted liver of sulfur with a small brush or finger tip will blacken it and not stain the wood. One of the reasons I switched to copper in place of brass where possible.I’ll try nipping the brass shank off with flush cutters and applying a blob of thick paint to represent the (square?) nut.
Allan,Hi Ted,
I found some data on the Cormorant class sloops of which Jalouse was a part, being in the second batch of 24 vessels launched between 1806 and 1813. These 24 carried 32 pounder carronades. The first batch of seven ships all launched in 1794 carried sixteen 6 pounder long guns when launched then converted soon thereafter to sixteen 24 pounder carronades and eight 12 pounder carronades.
From what I could find Jalouse would have had sixteen 32 pounder carronades, eight 18 pounder carronades and two 6 pounders. Hope this helps.
Hi Ted,The description in the instructions says 18 32 pounders What size would the blocks be In millimeters
Made up a scriber and that improved my accuracyI make pilot holes with a scriber or a needle mounted in a paintbrush handle. They help to keep the drill from wandering.
