Hit the craft store and picked up some Elmers. They didn't have the Best Test brand. We'll see if I can handle the smell
Thanks Olivier/Paul.
True story.The benefit is ***NO SANDING CHAR*** like kit builds, plus the joints are super tight
Grainger may well have bearings that would work. Worth checking out. I see no harm in buying a new saw to lift your spirits while getting the old saw back in working order.Sorry for the passing of your Preac saw. Are you able to replace the bearings or is this a good excuse for upgrading? Fingers crossed for the Brynes!
Olivier/Namabiru,Grainger may well have bearings that would work. Worth checking out. I see no harm in buying a new saw to lift your spirits while getting the old saw back in working order.
I'm hoping Donna from Byrnes contacts me. I e-mailed and left a voicemail.Hold out for the Byrnes. That's my final answer.
Jeff,Hey !
Getting here a little late, but following now.![]()
Hi Brad. I am a little bit late but hopefully there is some place for another chair? I have no preference to sit next to anyone. They are all decent people as far as I know.Greetings, from Lake Pontchartrain, outside of New Orleans.
The Boudriot/Berti monograph arrived the day before the mobile workshop left Colorado.
Shipyard supervisor poured over the plans and sawdust will fly tomorrow.
The first major decision was the room/spacing of the frames:
1. 10 frame/spaces were measured (red line below) at 4.56 inches OR .456 inches/1 frame
2. 3 frames were measured and averaged at .386 inches
3. 3 spaces were measured and averaged at .070 inches
4. 3.86 + .070 = .456 inches. This agrees with the 10-frame average!!!
5. This results in full scale frame thickness of 18.53" and space of 3.36"
This seemed a very big "frame" to "space" ratio, but it agrees with the Boudriot plans, as well as two superb models that I will continue to reference as I work this scratch build:
1. Alexandru Gurau's model of Salamandre:
2. From the SOS forum, "Jimmy's" incredible build log of Salamandre:
Tomorrow, the stockpile of .25" thick alder slates will be sanded to .193" so frames can be laid out and glued.
This process will occur over several months, up the Eastern Seaboard to Maine and then west to the Upper Peninsula of Michigan.
Welcome Peter!Hi Brad. I am a little bit late but hopefully there is some place for another chair? I have no preference to sit next to anyone. They are all decent people as far as I know.
Alan,Do you add any weights to the frames while the glue cures so they do not move/lift? I do this for the initial gluing and again when the chocks are glued in place if the frames are chocked. Same idea if I go with double frames in place of single chocked frames.
Is the glue still not set at this point? Your idea of a board sounds really good and got me to thinking. Better than using the scrap spacer pieces like in my photo, which is to keep the weights from tipping, a clear board like plexiglass across the assembled frame could work. It is clear and if anything moves in the process, it can be seen and fixed before the glue dries.Once a frame is complete, I place a square of melamine board (photo), with weights on it, overnight.
