HMS Vanguard - Amati - scale 1:72 - Foto
Андрей, тренцевать ванты не надо, но передние ванты в любом случае нужно клетневать. Многие капитаны считали, что тренцевание не улучшает, а ухудшает состояние вант. Штаги могли быть с тренцеванием независимо от вант. Придерживайся такелажа, показанного в сообщении 167.
Утки на вантах ставь. Для их примерного расположения воспользуйся фотографиями Виктори.
please read
Hi. I also bought such a toy. I also bought a fine-tuning vise for her on Aliexpress.
Yes, it's a nice little motor, useful, even though it looks like a child's toy. I bought micro drills with a thickened shank for it on Avito, made in the USSR, 20 rubles each, they're good, they drill brass without problems. If you're interested, here's the link-https://www.avito.ru/moskva/remont_i_stroitelstvo/sverla_po_metallu_ot_0.12_do_3_mm_sssr_4152862560?utm_campaign=native&utm_medium=item_page_android&utm_source=soc_sharing
Excellent build generally. Only two comments: 1: the landyard is
running Riggend and as such should use the white or yellow rigging thread. The second -but as the ship is not completed, this will or can be taken care of. Your setup of the shroud are completely correct. You have, as not many, the correct diameter between the shroud and footstep (weblings) Well done Mate.
Assome of you may know, my wige and selves has been the siskbay, so many commnt comes to late, but may be a help to newcommers.
I have in fact for some time ago -inanother side -made the compleate standing Riggen ot the lover mast and bowsprit. I can dee in your Riggen Many semilarity
el Cape
Изготовление мусинга грот лось штага.
Штаг- 1,8 мм.
Бусина- 4,4 мм, диаметр отверстия 2,4 мм, бук.
Канат для оплетки бусины- 0,3 мм ( Gutterman e121, 3 пряди, 2 каболки)
Making a musing grotto moose stay.Stay - 1.8 mm.Bead - 4.4 mm, hole diameter 2.4 mm, beech.Rope for braiding the bead - 0.3 mm (Gutterman e121, 3 strands, 2 cables)
