When you first were showing the deck installed, I was rather disappointed to see so many beautiful below deck's details disappear from sight. Seeing your picture from the inside out however has gotten me over the initial disappointment: she looks marvelous.
As far as the mystery of the lashing of these hatches is concerned; it must have been a simple, robust process, not something gremlins could accomplish.
The ‘disappearance’ was also a moment in my mind and considered a partly decking like the Bluenose, Johan. A kind of ingrained way of working.
But I had watched the tying of the hatches from the beginning and always had a full view of the inside. Hadn't had to fill the holds completely with barrels. Only the front was enough. But they are now, as far as visible, in their original stacking manner.
Now I have arrived at what was on my mind during the entire build: will plating the frames result in a tight hull?
Thanks to the earlier alignment of the rows of plates:
I was able to apply the next 3 rows quite quickly.
I had already applied 2 rows with 005"/0.13 mm plate:
But the thin material is counterproductive, especially in the places where the hull goes from concave to convex. I then have to work the plate on 2 sides, which is roughly the same as forcing copper plate:
The thin material does not retain its shape but goes its own way with further deformation. When gluing, the surface also melts a little, which in this case also promotes further deformation. This was already clearly visible in the first 2 rows where the curvature of the shapes was not yet very strong.
That is why I switched to 010"/0.25 mm plate. This was much easier to deform.
Then this is the rough result so far:
Now still in bright over-shining white, but with a little subdued light the contours come out nicely.
On the plates I have marked the position of the frames. Vertical rows of rivets should come there. I just have to test whether I first spray a base coat and then stick the rivets. Which gives the best adhesion of the rivet decals. I have to stick the waterline to make the transition from black to light blue. Maybe the pencil lines will remain visible with a thin base coat.
The plating on the back has a specific gradient. Here is the original:
I had to mirror it to be able to compare the visible starboard side with my port side.
A brief explanation of the next step:
I now have to make the 6th row very precisely to size in order to be able to attach the bulwark to it:
The 6th row (A) must protrude 1.6 mm above the outer angle iron (B) of the waterway. The plate for the bulwark (C) is on top of it, on the inside of the 6th row.
There are then 2 rows of rivets over the entire length. Skin plate A has a connection with angle iron B and bulwark plate C is attached to the top of skin plate A. At the top of the 6th skin plate, the connection with the bottom of the bulwark plate is covered with a half-round bumper.
Wow! What beautiful hull lines she has, truly a graceful form from stem to stern. You can really see the balance between elegance and purpose in her shape. Bravo, mon ami! That’s the kind of craftsmanship that makes this hobby such a joy to follow.
Thanks for your compliments and very nice words, Jim. ‘Graceful’, that the right word for her.
The plating looks like it reveals the hulls shape quite well. It will be interesting how the light plays along its length (shadows, high and low areas) after you paint it.
I bet the rivets play an important role in the light's reflections too.
Thanks, Daniel. I have the advantage that the hull of the original Balder is also ‘not perfect’. That’s the (dis)advantage of a hull riveted on frames:
(Source: from the internet, picture from Ernst Lohmann, after placing the new masts on the Balder.)
Here is the light almost along her hull.
Now I have arrived at what was already on my mind during the entire build: will plating the frames result in a tight hull?
Good evening Peter. Very impressive work. I am holding my breath for your next step….. Cheers Grant
Very nice hull plating Peter. I have a similar experience using brass. .005” is too thin for almost any application. The minimum thickness that I use is .010” even though it’s over scale. Fortunately, all that the eye sees in either case is “thin.”
Roger
Thanks for the compliments, Roger. I am glad that we have the same experience with the useable minimum thickness.
The next step I could make was the 6th row of hull plates:
Started at the front with the 1st plate that moves slightly outwards. Then 4 plates that are increasingly positioned slightly more upright until just past the middle. Then 3 plates that move further outwards and form the overhang of the aft ship.
To be on the safe side, let the plates protrude 2 mm above the outer corner line where the bulwark plates are attached.
I cannot yet glue this row and start working on the bulwark. First, 6 scuppers have to be made in this row:
There are 6 holes in the waterways for this purpose with 90 degree pipes that drain to the side.
The photo also shows 2 of the 3 valves that are in the bulwark. These will be done later when cutting the bulwark plates to size.
First placed these 6 tubes in the construction starboard side part:
With the corresponding holes in the waterways:
Based on the dimensions I could now drill the holes in the plates of the 6th row:
Then I can now place the (parts of) the tubes on the inside of these plates and the waterway.
All in all, I have to think very carefully about which parts to apply at which step.
First placed these 6 tubes in the construction port side part:
Bravo bravo. So very good and I did not have to hold my breath very long…
