- Aug 10, 2017
Frame Installation:
I use a spray re-positional adhesive to attach the patterns to the wood, and most of the time I use too much, and it is difficult to remove the pattern. I use mineral spirits to break the bond, and the paper comes off easily, the mineral spirits doesn’t stain or leave residue on the wood.
After removing the patterns, I drill holes in the frames directly above the keel notch for an 18-gauge brass pin, clamp the two end frames in place on the build board and drill holes for the pins into the top of the keel, glue and pin the frames in place using a square and the gantry cross bar to check the alignment.
I used some 1/8” thick bloodwood to box in the gun and sweep ports, 1/16” material would have worked just as well the ends will be covered with planking. By cutting blocks the same size as the interior of the ports assembling the port frames with magnets on a steel plate is fast and easy.
Four small spacer blocks need to be glued to the aft side of each frame excluding the aft most frame before gluing the hull together. I usually start at the bow and work my way back to the stern.
This set of photos shows the frame installation.
