- Oct 1, 2023
They seem to be holding better. I'm using more glue and got out a new bottle of CA.Well, that's one way to do it. You may find that you now have more adhesion problems than you did before. Before you commit to the hull, might I suggest a test by prepping a piece of scrap the same way you did your hull and spraying it also. Make sure it has had plenty of time to dry. Then try gluing some extra plates to it and see how they hold.
Ted, Just my opinion if you are going to have 3 rows on your "belt"I would not do the 3rd row until the rest of the hull has its plates in place. This would make it easier to trim and overlap the belt rows with the other rows and perhaps make things easier and neater.The first row of the belt plates is complete. Much easier View attachment 527754
Oops, half the third row is on.Ted, Just my opinion if you are going to have 3 rows on your "belt"I would not do the 3rd row until the rest of the hull has its plates in place. This would make it easier to trim and overlap the belt rows with the other rows and perhaps make things easier and neater.
Rob
Thank you.Ted! The gore lines look excellent! I'm sorry you ran out of plates but pleased you found a good source for replacements! She's coming right along! Keep of the good work, sir!
Blessings. Peace. Gratitude.
Chuck
