VOC ship The Prins Willem (scale 1:75) Year 1651
Thanks Ab, you are absolutely right about this point. I mentioned in my post before
I didn't get them in a nice way onto the boltrope. It keeps looking messy. That's why I choose the grommets, they looked the best of all. Yeah I'm ashamed about it, but to small for correct details.
The bigger sails will give me a better try, because of the bigger rope on the sail. Circular cringles are used on modern sails these days. They are placed in the sail.
The next small sail I make, I will try to don't let them look round but oval by sewing them on 2 points first and then the middle point. And the main and fore sail are big enough to give more detail.
Hi Stephan,
I did a visual cheat (scabbed in a short section of rope under the cringle loop which was a direct continuation of the bolt rope):
Hi Stephan,
View attachment 533785 View attachment 533786
That's a good solution to look at. Looks not messy at all. I'm gonna try this on my test sail, if possible. the sails are very thin in my case, that's why it is so difficult to glue without mess. Thanks Paul
I changed the "leuvers" a bit. just make them a little more oval.
They are still not what I want, next sail will be different. I leave this one, It's a small sail and with the bare eye it's hard to see.
You can see the reefpoints pointing to everywhere, they are not heat treatment till now. First the robands.
Ashley's shows them in this way 1264. Not the yellow.
I made 3, but I'm gonna look if I can do the seizing better. Don't like it how it's done by me now. The robands are 0,35 mm. and the seizing is 0,23 mm.
Lovely work, Stephan. Could you just seize with thread? It's so small no one will notice you didn't use proper rope.
A joy to see you working on this ship again!
I give that a try Paul, because it's real small and almost not visible when the yard is attached.
For me it's a joy too, even if it's only a few hours.
Hey Stephan,
really nice work. It is very good.
regards
Günther
Good morning Stephan. Fantastic my friend. I love your attention to detail and the redo of the cringes says it all. Now I know how to make a tiny rope grommet….thanks. Cheers Grant
I hope that many members are following your sail making process. It is really nice to see sails that look like.,,,... sails, rather than pieces of burlap with oversized seams and stitching.
Your sail work is so impressive Stephan. I’ve bookmarked your posts for future reference.
Thanks guys for the nice words, my goal was to show how to make sails from paper and how they will look. Surprice, it came out very good. I like them also, looking realistic. I hope that furling these sails will come out as well too. Like Allan says that details look oversized when made of piece cloth. I got that problem too. There are some cloth that look good, bud hard to get, seaming them is still hard to do.
Hey Steffen,
I'm really impressed by your sails. I want to build my Athena in the same scale as you are building the Prinz Willem. That's why I like your sails so much, because they don't look bulky and fit very well in the 1/75 scale. I am looking for a good sail cloth. But what you are doing with the Japanese paper looks great! Respect. :D Thumbsup
Cheers
Günther Ship-1
Hey Steffen,
Cheers
Günther Ship-1
Thanks Günther, if you can't find the correct paper in Germany you can try DeKwast.nl they have big pieces kashmir.
They just asked 7,99 for sending to Germany.
The paint I used was this
118 ml is what you need for 1 set of sails, maybe more. I got 250 ml tubes from another store.
the only difficult part is when you paint the paper and take it of your table. The rest is easy. When dry, it is very strong.
Oh wait, the most difficult part is to glue the bolt rope to the sail.
Thank you all again for the likes, thoughts and compliments. They always make the day.
I found some time again to not have to work on the rope walks, drum sanders or 3D printers.
I'm getting back to working on the sail and now I have to figure out what strings and blocks and how it all comes together. Nice figuring out with a pile of books, documents on the PC, pictures and drawings I can find or have made myself.
Straighten the reef lines will be done in a later stage of the build. Just before I hang the sail
A lot to research..... a lot.
And of course making parts. Tiny parts
The strop to hang the crojack, big grommet for the block and an eye on the strop.
2 block for the sheets on the colar of the stay. Both with grommets. (2 mm. blocks) rope is 0,22 mm.
pdf with my research to keep in mind how things supposed to been done.
Now I'm gonna make the lift blocks on the mast and the shoe? block on the crojack ends.
Hey Steffen,
You have my respect and I think the way you have approached and presented the subject is spectacular! It would be an honour if I could recreate your sails. I hope that would be okay with you? Of course I'll use the English sails and not the NL ones. I've already ordered the colour and the Kashmir paper and they should arrive this weekend. I really hope I can do it the way you have shown us. I'm going to build the first sail for my little dinghy. Let's see if I can manage it. It will be furled, of course. That would be my productive test for the Athena's sails. I have one more question: May I ask how big or what dimensions your sails are? As I am also building on a scale of 1:75, that would be a great help to me.
Many thanks and best regards
Günther Ship-1
Hey Steffen,
Günther Ship-1
Thanks for liking and visit my log Gunther. You are free to use my sails if you need them. But remember my ship is not the same. But I put all the files in the attachment here. If you print them you can see the scale. This is 1/75
Success with sail making, if you follow the instructions it will be easy. I only had to redo the first one.
Thanks all for the likes.
A little update, little in parts not job. That was big.
all the blocks and the blocks attached to the yard.
These blocks on the yard are big. I found this drawing online source vaartips.nl Tekening van Frederik J.Weijs
