Nice ! I'm a long way off from there.
That' a bit annoying, mate. Did you check those parts number twice, at least?All going OK
Thought I would look at doing something completely different So Bought a 3D Printer Impressed so far
Lots of Naval bits to build (And Navel !!)
But also started the Fore Platform for a change
THe parts E2 2,3,4,5 all have 4 mm slots for the joining parts
It says use 4x3 But the parts are 4mm so It looks as though they should be 4x4
3mm Sideways is not right
Any body got that far
anythoughts while i get back to FRAMES
thanks
That's a bit annoying, mate. Did you check numbers of those carlings twice?
Yes All parts are ttally right it says on the arrow going out to the left side 4 x 3 stripsThat' a bit annoying, mate. Did you check those parts number twice, at least?
Nothing to do but have them from scratch, then...Yes All parts are ttally right it says on the arrow going out to the left side 4 x 3 strips
And the Shaped frames are 4mm as well
All cutting is done on main E2 16 - 13
WAiting to see if anybody else has done it
Thanks
Have you looked at thisAll going OK
thanks
