Nice !  I'm a long way off from there.
|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
That' a bit annoying, mate. Did you check those parts number twice, at least?All going OK
Thought I would look at doing something completely different So Bought a 3D Printer Impressed so far
Lots of Naval bits to build (And Navel !!)
But also started the Fore Platform for a change
THe parts E2 2,3,4,5 all have 4 mm slots for the joining parts
It says use 4x3 But the parts are 4mm so It looks as though they should be 4x4
3mm Sideways is not right
Any body got that far
anythoughts while i get back to FRAMES
thanks
That's a bit annoying, mate. Did you check numbers of those carlings twice?
Yes All parts are ttally right it says on the arrow going out to the left side 4 x 3 stripsThat' a bit annoying, mate. Did you check those parts number twice, at least?
Nothing to do but have them from scratch, then...Yes All parts are ttally right it says on the arrow going out to the left side 4 x 3 strips
And the Shaped frames are 4mm as well
All cutting is done on main E2 16 - 13
WAiting to see if anybody else has done it
Thanks
Have you looked at thisAll going OK
thanks
The 1/96 build not withstanding, everything I’ve ever seen indicates they should be level with beams.Just watched the 1:96 Video and YES there is a gap
On 1:96 the Frame is 2mm and the Carlings are 1.5 so that's correct with a gap at the top
Interestingly he use thin CA Glue My Plans are all in sleeves that go in a binder so stop the glue sticking
ONWARD AND UPWARD
Not got that far yet Interesting to here how others dod itLooking very nice indeed. I'm part way throught the 1:96 boxwood version and would like to ask you how you faired the interior bow and stern frames once assembled, and whether you could get a flat and level transition from frame to frame?
Richard
Sorry I am talking about the Orlop For PLatformThe 1/96 build not withstanding, everything I’ve ever seen indicates they should be level with beams.
IMHO, do NOT use thin CA, it migrates everywhere and makes a far weaker bond, use medium or even thick.
They stay where put, allow adjustment, and are gap filling.
I have extensive CA experience and actually am about 1/2 way along installing all of the deck clamps using medium and will do exterior planking with it as well. Just remember a little dab goes a long way. Also use it only with long thin extender tips allowing very precise application.
Not sure if that was directed at me, but it boils down to lots of sanding.Looking very nice indeed. I'm part way throught the 1:96 boxwood version and would like to ask you how you faired the interior bow and stern frames once assembled, and whether you could get a flat and level transition from frame to frame?
Richard
Thanks, I'll have to look into that. I've not tried belt sanders before.Not sure if that was directed at me, but it boils down to lots of sanding.
Most of it gets you pretty close using the Wen hand held belt sander that I posted an image of a while back, using finer belts( easy to go too far with a heavy hand, you have to keep it moving). It reduces effort substantially.
Your task is harder given you have a much smaller space and box is that much harder, just no substitute for time.
![IMG_20250902_094213[1].jpg IMG_20250902_094213[1].jpg](https://shipsofscale.com/sosforums/data/attachments/525/525421-3dd70f9ca30c77adb672ba2cd8d6833c.jpg?hash=gGOwZPSoQW)
![IMG_20250902_094204[1].jpg IMG_20250902_094204[1].jpg](https://shipsofscale.com/sosforums/data/attachments/525/525422-22ee3af31c448b6fb3ed114d3e7d00d1.jpg?hash=p9sSZOSYDB)
Couple guys building the 1/48 have bought the inexpensive Wen unit ant they love them.....real time saver.Thanks, I'll have to look into that. I've not tried belt sanders before.
Good morning Richard. Looking very nice indeed. Cheers GrantThe 1/96 build not withstanding, everything I’ve ever seen indicates they should be level with beams.
Just realized your Orlop is built( as per instruction) upside down, all carlings level with surface.Sorry I am talking about the Orlop For PLatform
Just wanted to do something different
Ive not used CA just said whet the guy doing the 1:98 used
Ive used Gorilla Wood Glue and Titebond
But will agre on CA Type
Congrats on making it to the last frame !Starting on the FINAL FRAME
Cant say i am not relieved But did enjoy the journey
Note i find it easier to join the frames that are flat first And then liift them insert the Fillers And finalise the gluing
its only taken 56 frames !!!
And now to get them mounted
1-36 are fixed
X1 - x9 are fixed
Need to sand down Y1 - Y 10 and Fix those
Trying to source some Pear sheet in UK as there is NO REPLY from Victor
