- Aug 10, 2017
Hi Mike, can this method be used on the Blanford MAIN DECK BEAMS, and cut the notches in the top part only, and what thickness would the top part be. THANKS Don PS hope I put this in the right place
Hi Don, yes you can use this method for the Blandford main deck beams, the top part of the beam and the carlings thickness are 1/3 of the total depth of the main deck beams. You may have to leave the arm beams a single thickness and chisel the notches for the carlings. It is good to see you working on the cross section again. Good luck with the beams.
Mike
