Nice to see your stellar work again Tony.
Thanks for the feedback I'll try to post more frequently in the future.Excellent work - All in perfect scale as well.
Thanks for the feedback I must admit I have been very tempted to cut the masts down and finish this ship as an admiralty model.Great job so far, I am excited to see you start the rigging, so many builds quit after the hull and deck! Can't wait to see more!
What a funny photo))) You have some very interesting rigging work ahead of you... I'm really looking forward to it, but I'm still very far from it.
Thanks I'm not sure where to start, I normally work fore to aft, bottom to top.What a funny photo))) You have some very interesting rigging work ahead of you... I'm really looking forward to it, but I'm still very far from it.
Good morning Tony. AHHH ....you are owning this. Cheers GrantToday marked a bit of a milestone, I've started fixing the masts in place.
I use a digital level and plum line to set the mast then use rope to hold it in place while the glue sets.
Tony
Wonderful work. Just my own 2 cents, but why not wait until the end to place the hammock nets? Like you said they are very delicate and likely to get damaged by other work.Hi
I hope everyone has had a great Christmas and best wishes for the new year.
I'm currently taking a break from the shipyard, lots of other things to do at this time of year.
This is my progress since the last log. As yet I haven't fitted the hammock nets, mainly because they are very delicate and I'm very likely to damage them while rigging. I decided to make the lower stays and shrouds first then tie them up after the hammock nets are finished.
I used a simple jig to set the deadeyes.
Temporary riged the deadeyes to get the right tension on the shroud.
Shrouds and stays on the fore mast.
I'll post more tomorrow.
Tony
This is the first time I fitted nets on a model so it's a matter of trial and error. I tried a few different methods (off the model) to make the hammock nets. I think it would have made the job much harder to do with the shrouds in place.Wonderful build!
Rob
I understand. On the Constitution cross section the hammock nets were constructed with the bottom part made so it will just fit onto the ship as one unit. Perhaps you may want to consider using a very thin piece of wood as a base and mount it all as one section when everything is finished (which is my plan because of my amazing clumsy hands)This is the first time I fitted nets on a model so it's a matter of trial and error. I tried a few different methods (off the model) to make the hammock nets. I think it would have made the job much harder to do with the shrouds in place.
Tony
That's a good way to mount the nets I hadn't considered this method. With the curve of the hull at the bow I think it would be difficult to match the two parts.I understand. On the Constitution cross section the hammock nets were constructed with the bottom part made so it will just fit onto the ship as one unit. Perhaps you may want to consider using a very thin piece of wood as a base and mount it all as one section when everything is finished (which is my plan because of my amazing clumsy hands)
Rob
ThanksExcellent work!
Part 2Hi
Tony
Wonderful Job!Part 2
I must admit I have been putting off making the hammock nets until absolutely necessary. This is how I did mine.
First the easy part fix the PE posts in place care has to be taken as they bend very easily.
It's hard to see in the photo, first I put the netting over the posts then threaded a piece of 0.3mm wire through the holes.
I used some thread to attach the netting to the wire. When finished I trimmed the excess netting.
Job finished, quite time consuming and very delicate work.
As I was really worried about damaging the nets I made some removable plastic blocks to fit between the nets. These make it a lot harder to damage the netting.
That's all up to date for now.
Tony
