- Dec 5, 2022
Hey folks,
It's finally finished. The little dinghy (cutter) really took it out of me. Especially since the dinghy was completely broken and I was close to tears. "Roll up your sleeves and don't give up" is my family motto! You have to fight for what you believe in!!
With a lot of patience and effort, I hope I made the best of it. Working on this scale was really new to me and, yes, exciting at the same time. The instructions were only of limited help, especially as I didn't know how to tackle the problem of the railing. I thought about how I could use the small UM9 assembly aid to help me. I reinforced the assembly aid with a mini piece of wood (diameter 0.2 mm) and used it as a guide edge for the plank. Then I clamped the hull of the dinghy in between. This created a stabilising aid so that the plank did not constantly slip away. With this aid, I was able to glue the plank at several points and thus glue and dry the plank several times. This involved several gluing steps. I glued it about five times, let it dry and then continued gluing along the railing.
I was really satisfied with the result and happy that it looks good. However, for the next two boats, I will not follow the instructions and will take steps that I think are better and faster so that the result is even better.
I have carried out the following work on the dinghy:
- 1. The transom U5, bow hook U6, jib boom bracket U7 and transom U8 are glued in place, then the railing is sanded down until it is flush with the frames.
- 2. Two outer planks UVW-48 are glued to each side of the boat along the railing, then the rudder U9 is glued to the transom, completing the cutter. Then varnished with clear varnish.
