Artesania Latina Anatomy of Lord Nelson’s HMS Victory 1805
Hey Alan,
Really beautifully done, and yes, of course there were larger buckets and tubs. Some were made of wood, known as wash tubs, which were used to wash large quantities of vegetables or even meat... or even wash troughs, which people used to bathe in. As always, you've breathed new life into the building. By the way, I was able to reorder part P70 and AL has confirmed that the part has been sent to me. :D Thumbsup
Video #29 Update
Part P70 arrived today so I fitted it as best I could. It has to be bent into an offset shape to go through the chain. None of this was shown in the video, just the part in position
I had to paint the lower part before fitting as it passed behind a brass ring which would not be there if fitted at the correct time. I have included a couple of stills from the video to help others with the positioning
Hey Alan,
Now I have an idea of what part P70 looks like. Thank you very much. I've ordered it too. I'm excited to see when it arrives. I always look forward to your progress and pictures. Thank you very much.
One Year On
It’s been one year today that I started this build.(27/11/24) I haven’t kept a note of how many hours I’ve spent to date, I think that would drive me mad thinking about how many hours of the 3000 or so they say to build it are left
I don’t work on her every day and there are the holidays and days out in between, so I just plod along at my own pace. I thought at the start that this would be a 4 or 5 year project for me.
Let’s see where we are this time next year
Hey Alan,
Really nice, and I've been with you for a year now. Your construction report is great! Please keep it up... My two P70 parts arrived yesterday... really tiny... :D Thumbsup
Hey Alan,
Hi Gunther
Thank you for all your encouragement and comments over the past year
I look forward to seeing your Victory starting in the future
Hi Gunther
Hey Allan,
Thank you very much for being excited about my win. I hope I manage to build it exactly as it was in 1765. I look forward to hearing your opinion and am so excited to see what it looks like. I will definitely take your tips and tricks on board... Thumbsup
Instructions video #30 part 1 completed
Plenty to do in this one so again I will break it down into a few sections
In the first part it’s back to making guns for the middle deck, 28 x 24lb on this deck. I won’t go into too much detail as it’s been covered before ( video #23) so will just show some progress pics
A couple of things I did differently this time. Firstly I glued the wheels to the axles, they don’t need to turn and last time I found it difficult to keep the glue at the bottom of the wheels when moving the guns into position on the deck. I think I mentioned last time that I didn’t like the look of the silver wire holding the wheels in place, so I looked at some photos of Victory’s actual guns and saw they were secured by what looks like a metal rod (possibly wood originally). So I bought some 3mm brass rod, cut it into short lengths and blackened it. I then drilled out the existing holes in the axles and glued the rods in place. I only have half of the guns actually in position on the deck at this point, but wanted to make the post today so I could wish you all a merry Christmas
Instructions video #30 part 2
I dragged my heels a bit over the festive period but finally got all the guns mounted on the middle gun deck.
Before I start on the pillars and beams I thought I’d just post this short one.
I made the furniture for the wardroom and painted up a few figures so I could create a little diorama in that area
Finally, although this is not done until the end of video #30, I decided to do the printed walls at the stern sides.
Instructions video #30 Completed
☑️ In this final part I measure and cut the various lengths and sizes of timber for the pillars before shaping them on the mini lathe. After painting they are fixed in position. Next I groove out the tops of the beams, paint and fit the led lanterns to the beams and wire them up. After fitting the beams in place the cables are then solder joined and covered with heat shrink tubing.
Finally I cut and fit the internal planking infills between the beams.
Hello Alan, :D
That looks fantastic! I'm thrilled and impressed by how well you're building everything, it's just great. I have great respect for your hard work. The guns look amazing!! I was really excited to see your progress. I can really learn a lot from you. Thank you very much for that. I'll use all of this for my Victory build...
A little diversion while I’m waiting for some paint to dry
Years ago when I was building another Victory kit I sourced some small brass buckets that turned out to be too large in scale, but I went to the trouble of making some GR cypher decals for them. I came across them the other day and decided to place some around the ships pantry with some sacks
Hey Alan,
Wow, that looks great. May I ask how big these letters are and where you had them made?
By the way, the figures look very nice. Are these the figures from AL for Victory?
Hey Alan,
Thanks Gunter
The whole cypher is probably about 2mm high. I made them myself by copying the cypher, reducing it in size using desktop publishing software and printing a batch of them onto clear decal paper in my printer
Yes they are the AL figures although I had to adapt the one sitting down
Instructions video #31 Part 1
Video #31 is quite a short length compared to some of the others, but the work involved takes quite some time, that’s because it’s all construction tasks that have been described in detail in previous videos like fitting decks, internal and external hull planking, gun port linings, wales and painting etc.
In this first part I deal with the decks.
Similarly, as I’ve already gone into more detail in my previous posts, I will just post picture progress which should be self explanatory.
Hey Alan,
That looks great. I do have one question, though: is the checked pattern a foil? I mean the green checked one. Because later it's black – did you paint over the foil with black?
As always, it looks incredibly beautiful!! Thanks for showing us. Thumbsup :D
