I want to thank all of you who have visited my build log, for the comments and/or likes. I was a bit overwhelmed by the number of nice comments I received. It felt like a warm welcome back, much appreciated dear friends.
Thanks Paul. Nothing escapes my file and steel woolThe softened edges of your work gives a very elegant look to this model. Well done, Herman!
Nice work on the bulwark, Herman. And those scuppers looks very realistic.I continued with constructing the part of the bulwark that gave shelter to the riflemen. It is still work in progress. On the outside a profiled slat will later be attached, but only after I have painted the outside of this section. Mind you, it hasn't been glued down yet, so still will get some refinement. Gluing will also happen after the painting is done. Then the door and fittings will be installed.
Thank you Grant.Good morning Herman. Brilliant. Your finish and the way the grain of the wood is exposed makes this eye candy. Cheers Grant
Hey Gunther.Hey Herman,
She looks so beautiful. I'm blown away. Your work is truly a dream. I'm a big fan of beautiful things, and your D7P is absolutely gorgeous.![]()
Thank you Peter.Nice work on the bulwark, Herman. And those scuppers looks very realistic.
Thank you for your nice words Mirek.Witaj
Ładnie wygląda poszycie, dobra robota Hermanie. Pozdrawiam Mirek
Thank you for visiting my build log @KAYA61. You're most welcome.Herman, I follow with admiration
Thank you Paul. Kind of hard to believe you cutting corners in your buildI admire those who create the 'pockets' for the beams in the clamps. Thus far I have 'cheated' and notched the beams themselves. Bravo, Herman!
I was thinking more in terms of beam locations along the length of the ship. You have to be very precise to cut the pockets ahead of time - and then install the clamps in perfect longitudinal symmetry, Again, I admire the approach.The advantage is that when I make deck beams now, I can plane them to the exact width.
Ah, I understand.I was thinking more in terms of beam locations along the length of the ship. You have to be very precise to cut the pockets ahead of time - and then install the clamps in perfect longitudinal symmetry, Again, I admire the approach.
