HMS Alert [1777] 1:48 POF by serikoff. (Two hulls: skeleton and fully rigged)
Everything is ready for gluing. I glued it with TiteBond II...
Then I glued on the temporary waterway, or rather, the second part of it. I applied it to the CA gel in dots so that I could remove it later.
After that, I sanded the surface first with 120-grit sandpaper, then with 150-grit. The mark was the absence of areas that had been coated with oil.
Then I widened the seams with a blade and after that I sanded with 240 and 320 grit sandpaper.
Recommendation! Do not use a needle to widen (calibrate) joints! Due to the varying density of wood, the needle may deform it differently, and the gap may be uneven (of varying thickness) and not perfectly straight. I also do not recommend using the sharp edge of a blade! If the sharp edge hits the glue or tightly fitted slats, the blade may slip from the gap and scratch the board. I recommend using the thinnest blade (as in the photo) but with the back of the blade. The principle is to use light, gradual movements along the joint, so that the blade follows the seam. As you go deeper, the sharp edges of the back of the blade will scrape out a smooth gap instead of squeezing the wood. The key is to do this carefully and very gradually, trying to scratch everything in one or two passes. The first passes should be made at a 45-degree angle, and the last ones at almost 90 degrees. This will ensure uniform blade penetration and calibrate the gaps to the desired thickness.
This is still an intermediate result. The long gaps between the boards are almost 100% ready, but I will still calibrate the gap along the waterway border in a slightly different way, I will tell you about this a little later.
A few words about why I do it this way:
1 - Seam calibration is a much simpler and faster method than precisely matching all the boards without gaps.
2 - When humidity changes, the wood has room to expand and the deck will not bulge. (This is precisely why this procedure was performed – sealing the seams with resin and horsehair.)
3 - There are no unnecessary steps when using various spacers to simulate caulking (resin seams), which complicates and slows down the process.
4 - Using bitumen in this method best simulates resin seams.
But again, this is just my opinion.
Hey Sergey,
As always, spot on. And thank you very much for showing us. I hope I understood you correctly: you pull the back of the knife along the planks, which creates these precise lines. But you don't fill in the gaps between the planks that this creates? Or do you fill them in?
P.S. Sorry for my poor English, I hope you understand what I mean? :rolleyes:
Hey Sergey,
Yes, absolutely right. I run the back of the blade over the surface, and the resulting gap remains. Then oil and bitumen get into it, and the area will be stained with bitumen, imitating resin. Because of the gaps, each board appears as a separate piece, not blending into a single plane.
Based on your workshop, descriptions, and drawings, even someone without much experience could attempt to build such a model. If something is unclear, you always explain the problem. I really like your journal, keep up the good work!
Hey Sergey,
Thank you for confirming me. That's great! Thank you! Thumbsup
Sergey,
Thanks so much for your wonderful explanations. Your work is incredible and your write ups help me to learn wonderful tips.
Cheers,
Rebus
Thank you. I also found very informative reviews at one time and was very happy about it. Now, I'm glad that I'm providing the same benefit. I hope :D
Lovely technique.
Thank you Thumbsup
Hey Sergey,
I'll be back on deck in a bit, but for now I'm still calculating the gratings, I'll be talking about that soon.
Sergey,
Cheers,
Rebus
Thank you for your praise. We will keep up the good work.
This post is for those who are interested and interested in learning...
Today I worked mostly in Blender. For those unfamiliar, it's a 3D modeling program.
I'd like to share a little advice.
Before marking out the deck, let alone nailing and cutting holes, it's essential to calculate everything! This will avoid problems later when something doesn't line up or overlaps.
How I do it:
1. First, naturally, you need to build the deck and finish it. In my case, I have two (one skeletal, the other planked. Therefore, I need to prepare two sets of gratings: a fully assembled one and just the frames).
2. Then you need to calculate the positions and sizes of all the fittings on the deck, nail lines, board joints (I try not to make joints right away, but glue whole boards along the entire length of the deck), and especially gratings and hatches.
3. When making the gratings: the most important thing is to calculate the number of longitudinal and transverse grating pieces and avoid making mistakes.
4. You need to make the grating first, and then build a frame around it. Don't do it the other way around, making the frame first and then trying to fit the grating into it. A ±1 mm deviation in size won't be noticeable if you see the frame is slightly larger after gluing the gratings, but reducing the grating to fit into the frame will definitely be noticeable due to asymmetry or thin outer edges.
5. Then, using the already made frame (with grating), mark the deck. Even if you find you've gone slightly beyond the required boundary (say, a beam), it's not a problem; you can shift the nailing line so the nails are at the correct distance from the frame. It's worse when the nails are already in place, but the frame is either far away from them, close to them, or even overlapping the nails. The same applies to other elements on the deck, especially the joints between the boards. If you need to move the nail line, you can also move the joints between the boards. However, if there are already joints, moving the nail line will result in artifacts and overlapping joints or misalignments. Again, no one will notice if the entire nail line and joints are misaligned without visualizing the beams under the board, but nailing that isn't in a single, straight line or joints that don't hit the nails will be very noticeable.
6. Then, nail along this marking and do a final sanding to ensure everything is level, and only then cut the holes for the grates and hatches.
7. After that, I'll install the deck in place, glue the waterway, and even then, I won't glue all the deck parts (gratings, hatches, etc.) in place, as work on the ship will continue, and to avoid damaging anything, fixing them will be done last. It's better to make everything disassemblable, so you can always try on any part, but still be able to remove it.
I'll be showing my lattice calculations soon; there's a lot to show! It'll be interesting!
I've been calculating hatches and gratings on the deck for three days now. And since I'm building two hulls, there will be two sets as well.
I'll probably create a separate thread on the manufacturing and, more importantly, calculations of gratings and hatches, but only after testing.
And today I'll share the guide I made for myself (because with my faulty memory, I might forget everything).
I highly recommend reading the post above (#709), as it explains the purpose of all this and the value of the time spent on it.
So, calculations for gratings, hatches and gangway.
Front grating
Note: The X-axis (red line) is the deck axis (in the photo, from right to left is from fore to stern). The Y-axis (green line, top to bottom) is from larboard to starboard. The Z-axis is the height. In short, the interface menu is at the front of the ship. (The exception is the gangway, where it's the other way around.)
1.1 - Blank: The wood fibers runs along the green line. The blank dimensions should be calculated based on the following steps; they will provide clear routing boundaries.
1.2 - The dimensions of the side grille pieces should also be determined after understanding all the subsequent steps.
2.1 - Routing grooves with a 1 mm cutter at 1 mm intervals.
2.2 - Routing in the same way, either simultaneously or remotely, but the groove depth should be 0.5 mm.
3.1 - Milling grooves with a 0.8 mm cutter at 0.8 mm intervals (of course, it's easier to do 1 mm, but in my case, that's the format and quantity specified in the drawings). Groove depth: 0.5 mm.
Note: It's better to mill across the grain first, then along it, that is, the opposite of what's shown in the photo. I decided not to redo it. This will reduce the risk of chipping.
3.2 - Length of side rectangles = interval + 0.5 mm (this is the depth of the grating's insertion into its side).
4.1 - Slats that are inserted into the longitudinal grooves (in my case, 0.8 mm thick).
4.2 - Length of protruding part = interval + 0.5 mm (as in point 3.2, and this will apply to all gratings below).
4.3 - The transverse side pieces of the grating are turned 90 degrees and glued to the base of the grating.
5.1 - The longitudinal side pieces are secured to the base in the same manner. When secured, the transverse pieces (4.3) are trimmed to the length of the interval (less 0.5 mm).
6.1 - After the entire grating is assembled, its upper surface is aligned to a single plane. The lower surface is then trimmed to the desired thickness and, if desired, profiled to accommodate the deck curve.
7.1 - The grating with the frame. It will be installed on the deck, which is covered with planks.
7.2 - After securing the grating to the frame, the upper surface is profiled to fit the deck's curve.
8.1 - The grating frame. It will be installed on the deck as a "skeleton."
8.2 - The connection of this angle is described below, as is the profiling of this frame to fit the deck's curve; it differs from the assembled grating.
9.1 - First, mill the first plane on the front and rear parts, as shown in the photo.
9.2 - Then mill the second plane.
10.1 - Then glue the frame pieces (4 pieces) together.
11.1 - Afterwards, they are given the deck profile (as specified in 7.2).
12.1 - In parallel, two more parts are profiled to the desired deck curve and glued in place at the mark to the depth of the lattice.
13.1 - Straight grooves for the grating are milled into the side frame pieces. For the version where the gratings will be assembled with the frame, for simplicity, a straight groove for the grating can be milled around the entire perimeter of the grating.
14.1 - This ensures a proper connection not only on the inside but also on the outside of the grating frame.
Anchor rope grating (hold)
20.1 - Route across the grain (along the Y axis) with a 1 mm cutter at 1 mm intervals.
20.2 - Then along the grain.
21.1 - Insert the 1 mm slats.
21.2 - The protruding edges of the slats and base should be equal to the interval + 0.5 mm to allow for immersion into the side grating pieces.
22.1 - Installing the front and rear grating sections as described previously.
23.1 - Installing the side grating sections.
23.2 - A tricky spot for the anchor cable. To make things easier, you can simply remove the excess. If I do the correct version, I'll show it in the review when I'm making it.
24.1 - Installing the side frames with milled joint grooves. (See also 26.1)
25.1 - Installing the front and rear frame sections with joint grooves.
Then the grating and frame are profiled to fit the deck curve (see 7.2 in the previous description).
26.1 - Grooves are made in the side sections of the frame before securing the grating.
27.1 - Locking strips are secured to the front and rear sections. (In the simple version, the grating rests on them, and after assembly, the entire structure is profiled to follow the curvature of the deck (see 7.2).
27.2 - In the complex version, the entire structure is first profiled without gluing the frame and grating together, and only then is the curved strip glued to the frame profile.
28.1 - Profiled grille assembly with frame.
Rear grating
30.1 All steps for the rear grating are identical to those for the two gratings described previously. The only difference is that the rear grating frame is significantly shorter and thinner, but the connection remains via grooves (see image 3).
Skylight
40.1 - Base: acrylic (plexiglass). 0.8 mm grooves are milled into it at 2.5 mm intervals.
41.1 - 0.8 mm slats are glued into these grooves. Their edges protrude by 0.3 mm; they will be recessed into the side sections of the structure.
42.1 - Mill 0.8 mm cross grooves at 2.5 mm intervals (including the slats).
43.1 - Glue the 0.8 mm slats into these grooves, also extending 0.3 mm at the edges.
To create a profiled structure, before attaching the cross slats, bend the base to the desired angle and glue the slats along this angle. After gluing, the slats will fix this angle. To achieve this, perform step 44.1 first, then 43.1, so that the front and back edges also bend to the desired angle.
44.1 - Attach the front and back pieces to the base.
44.2 - Then glue the side pieces (the principle is the same as described previously, but the depth is 0.3 mm).
45.1 - Skylight with Frame. For complex profile shapes, the frame must be prepared as described above (see 9.1-14.2).
46.1 - Skylight Frame (see 9.1-14.2)
Gangway
Note: The ladder is accidentally rotated 180 degrees, so its front part is facing left!
50.1 - Front frame part with milled grooves for connecting to the side parts (51.1)
50.2 - The rear part is first milled along the plane for part 54.1.
50.3 - Then the end groove is milled for connecting to the side parts (51.1)
50.4 - The middle part is divided lengthwise into two halves (not shown in the image; to understand the principle, see 54.2 and 55.1)
51.1 - Side frame parts with grooves for connecting to the front and rear parts. Gluing the frame.
53.1 - Frame profile for deck curvature (see 7.2)
54.1 - Second section of the rear wall, previously profiled for deck curvature along with 53.1.
54.2 - A similar section is also attached to the middle section of the frame (not shown in the image; this was previously discussed in 50.4).
55.1 - Routing grooves for the boards on the side frame sections. To simplify the process, this routing can be done along the entire perimeter (both the back and middle sections).
56.1 - Filling the space between the grooves with slats longitudinally.
57.1 - Installing the lid mechanism guides.
58.1 - Installing the mechanism hinges. For simplicity, the hinges can be glued to the housing. For a sliding lid, the hinges are glued to the lid.
59.1 - Transverse fixation of the lid boards. The boards are bent to the frame profile, glued separately, and then glued to the hinges if the lid needs to be movable.
60.1 - Gangway frame for the "skeleton" body
60.2 - A partially retracted lid with no lower deck (the lower deck is painted black, and only the ladder is visible through half the opening).
60.3 - A fully closed lid (the simplest option).
I hope you found this information interesting. These calculations apply not only to this model but to others as well; the key is to understand the logic, and the numbers can be substituted for any drawing and scale you need.
Front grating
Rear grating
Skylight
Gangway
Hey Sergej,
I had no idea you were so good with Blender software. Your explanations are once again world class, and I'm very happy to hear from you. Your drawings in Blender are fantastic. Actually, I think you should have a professorship. Because I think you would be a very good teacher. Just great. Thanks for showing us. :D Thumbsup
Front grating
Rear grating
Skylight
Gangway
wow ! I agree with Gunther above ! Absolutely amazing work !
Hey Sergej,
Thanks, friends. If you were impressed by my skills in Blender, even with even the most simple geometric shapes, you'll definitely enjoy this thread. There are links to my first review (Victory), which most people know me for. Enjoy ;) :cool:
Not so much your skills with blender (although they are also impressive) so much as showing every little detail for building all the grates and hatches ! :)
Again, Thank you !
As soon as I get into Blender... It'll take a while.
Today I modeled (as my wife calls it) a coffin for a ship. More precisely, there will be two of them. One for the skeleton, this one, and the second for the second hull – it's a simpler one, since after the entire hull, all the masts and rigging are completed, before the ship is assembled, a second, larger coffin will be made for the finished model. ROTF
I'll be commissioning all of this from a carpenter. I could, of course, do it all myself, but I don't have the materials, the massive equipment, the space, or the time... so I'll trust the professionals.
I used a 3D model of a boat as a reference, so I could visualize what it will look like.
The slab and corner stand are made of ash. I'll likely darken them with oak stain or choose something from samples and then seal them with Danish oil.
The columns/uprights will be brass (I already received four of them from AliExpress).
The frame will be glued like a picture frame at a 45-degree angle, using 5 cm beams, with a slightly thinner slab in the center to lighten the frame.
An 8mm-radius chamfer will be made around the perimeter to simulate legs and to allow the entire structure to be gripped by sliding fingers through these chamfers.
A 3mm-thick plywood covered with either billiard cloth or leather (I haven't decided yet) will be attached to the base to create contrast.
The wedge-shaped stand raises the ship's bow by approximately 4.5 degrees. It will be done in the same color as the rest of the slab.
I plan to make a small composition on the cloth, including the following: a stove (from the ship's kitchen), anchors, and perhaps a grate for the anchor cable, a row of cannon carriages on each side, and, if desired, even a mast and yards, but that's not certain.
For the protective case, I'll be ordering 3mm plexiglass and gluing it to a size of 700x250x300. That's approximately 10 cm at the top, front, and back, about 5 cm at the sides, and a 4.5 cm bottom height for the columns and corner stand.
The protective case will be secured with four screws, two on each side, to the base.
I'll describe all the production stages after receiving all the components, but I think it will be nice!
Ship-1​
The cabinets look great !
You might consider covering the piece in the bottom with billiard cloth that is blue instead of green. just a thought.
Thank you. Yes, I thought about that, but I need to look at all the options, including leather. It's just that everyone usually uses green. The main goal here isn't color, but contrast, to separate the stove from the model, but I'm also considering blue.
In addition to the ship case, I also designed and ordered a workbench and protective box for the Proxxon MF70.
This is essentially a table with a pull-out drawer for various consumables: milling cutters, burrs, vises, etc.
There will be a reinforcing plate above the drawer. The machine will be secured to it, and a protective box will be held around it.
The box can be easily removed during work and put on to protect from dust and damage.
The dimensions are indicated on the drawing.
Important! The dimensions 310 x 350 are the dimensions of the inner slab (step) around which the frame is secured.
The overall width and depth are 13 mm larger on each side to allow for space for the frame installation.
The material will primarily be laminated alder. The drawer will be on ball bearing guides. The frame will be made of 2mm plywood, reinforced with 8mm beams, held in place by four screws. (For clarity, I've disabled the visualization of the front and top walls.)
It's a shame it won't be ready until after the Christmas holidays, and I have no idea what it will look like yet... I hope I like it. I'll definitely show you the result.
I already have a milling machine, but I haven't made ball bearings for the Z-axis yet. I'm waiting for them from AliExpress... and I understand why this absolutely needs to be done! The factory system is simply awful. I don't understand why they don't make it with bearings right away (the cost is negligible), but oh well.
First, I calculated the position of the columns (the first and last paired frames).
Then I turned the base under the router stand 180 degrees and screwed it in with 2 screws (the mounting surface allows everything to hold in place anyway).
I had to place dumbbell weights under the machine and clamp everything down as tightly as possible.
We drilled gradually to prevent the wood shavings from clogging the drill bits. First, 1 mm, then 2 mm, and finally 2.5 mm. Then, I used a screwdriver to cut the threads with a thread cutter. After that, an M3 stud (like a meter-long headless bolt) screwed neatly into the hole.
I did this for two hull, but first I’ll tell you about the second one.
I drilled the hole as described earlier, tapped the threads, and then screwed the stud in.
Then I installed the case horizontally so that the stud could hang completely free from the bottom.
And inside the hull, I screwed a brass cylinder with a thread (like a long nut) onto a stud.
This way, I was sure everything was perfectly vertical. Then I filled the pre-drilled hole in the plastic with SA gel. This firmly secured the bottom of the insert.
I reinforced the upper part of the mortgage with wooden structures, which were fixed to the hull with СА gel.
The safety margin is more than sufficient. All these reinforcing structures will be covered with small boxes painted matte black. This way, nothing will be visible through the gratings and hatches.
But with the first hull, what I feared happened. The carver made a defect in the keelson. There was plenty of room for the wood, but cherry is fragile (unlike pear), and it didn't hold up. :eek:
My attempts to disguise this area were predictably unsuccessful. The oil coating naturally revealed the joints even more...
... I was a bit disappointed, of course, but I came to a completely logical conclusion... there were so many things about this area that I wasn't happy with from the start.
Firstly, there was a gap, unnecessary joints, and I had to cover up the area the manufacturer had done incorrectly... and secondly, I absolutely didn't like the entire keelson detail, or rather the grain of the wood.
So that's what I decided to do. I thought I wouldn't show the planking on this hull, but! Circumstances forced me to, and I realized it wasn't a bad idea.
I'll partially finish the lower four planking chords (it's good that the joints are close together near the stern). I'll also demonstrate the principle of joining the clinker planking. This will be interesting, since it's hard to see on the second model due to the full planking. Plus, this will not only conceal all the imperfections and the grain of the keelson wood, but also almost completely hide another detail (under the aft frames, in the shape of a crescent), which was implemented differently in the original drawings. In fact, it wasn't there at all. So I think this solution has only advantages.
And in the front, instead of one top chord, I'll make two more. And I'll show you where the boards connect, but from the other side of the connection.
Well, that's it...
...two decks are almost finished (everything inside the hulls is also ready), and next I plan to make the grilles... but the bearings for the Z-axis need to finally arrive.
I'm currently selecting materials and thinking about the color scheme... it's difficult, especially when you have more than eight shades of pear.
I think your idea for the limited planking is a wonderful idea !
I'm amazed you are able to get such clean holes from a regular twist drill !
Brad Point drill bits will give you a much cleaner hole. :) You might look into some.
