DE 7 PROVINCIËN (1665) 1:50
It seems like I'm jumping around a bit regarding the construction sequence, and that's probably true. I now wanted to complete the interior planking of the main deck bulwark. To do that, I wanted to install the deckclamps for the quarter deck first on the aft portion of the deck and then fill the remaining space with planking. At the same time the deckclamps for the forecastle were installed.
Again some very nice fitted parts, Herman. And taking off the sharp edges makes it complete.
Thanks, Peter.
Rounding the corners of the planks around the pulleys(/sheaves?) in the hull helped me in this case to neatly resolve the existing situation where the pulleys were, in my opinion, located a bit too deep in the hull.
Awesome, Herman! How did you cut the matching cambers on the beams (the round-ups)?
Thanks Paul.
After planing some scrap wood to the correct thickness, I transferred the curves of the foredeck and quarterdeck from the construction drawing and roughly cut them out with the band saw.
Then I cut the beams to length so they fit in/on the deck clamps and then I shaped the convex side with the disc sander (several planks at a time).
Since I don't have a spindle sander, I have removed the outer protective cover from my disc sander so I could trim the concave side to size using the outside of the sanding disc.
I do this by eye until the curve is even with the convex side and the thickness is approximately 6.25 mm.
Thanks Paul.
How delightfully hands-on!
For the Kingfisher I did basically the same thing with the transfer of the curve via a template - used a disc sander for the convex surface - but then used a mill with a jig to cut the concave surface to a standard thickness.
I have quite a number of decks on the Saint Philippe and I am looking for a way to standardize beam fabrication.
