Bluenose I - YuanQuin 1:72 - Loracs (in progress)
The nice part with those CAD software's is that, in principle, they are working alike. Once you learn one... it mostly a matter of interface design differences. So far, I'm going around the 10 editable files limitation by changing the "read-only" flag back and forth on a needed basis. "Read-only" component/parts can still be use in a sub-assembly/assembly has such. If it became an issue, the switch can be done.
Deck beam: I'm back to the build. I installed the 3 deck support beams. You can see in the close-up more details on the modified front deck, much lower to later accommodate the bunkbeds. Similarly, at the back, the floor of the captain's room. It was then time to add some Linseed oil to the area below the main deck. All the tiny nails are starting to show up. It is quite amazing how linseed oil enhances the detail, plank definition and nails.... it almost looks like laser etched.
yea! this is the first build I used it. It indeed brings everything to life. I was very conservative in the past but @Peter pictures convinced me to give it a try. It does darken the wood a little... but the color is nice.
View attachment 577548View attachment 577549View attachment 577550
It’s looking very nice with the upcoming treenails, Loracs.
Half-Decks: I decided to build the half-decks off the ship. This gives me a first opportunity to practice with Fusion 360 and design the plan based on precise measurements from the bluenose. Plans are drawn, cut and test fit. The decks are then built by side-gluing 3mm strips. The decks are slightly longer than needed, so later I can cut them precisely to the side walls. As a bonus for future builders, you will find my cross-beam measurements on the plans.
Note: Many may already know this but most printers do NOT print at 1:1. After several trials and errors, I found that mine needs to be set at 102% to print at the appropriate scale.
Mid-section deck: It just takes a little longer to do. Just remember when building, to adjust planks junction to the cross beams. As with before, it was cut longer than needed for future adjustment. Lastly, waiting for the glue to cure before handling to much --> the strips are side glue only. Once on the ship the deck will be supported /glue to the cross beams. As with the ceiling, I used a 5-steps for the spacing of the planks. Is it accurate? I could not find any more information... so I just picked one.
Note: the plan in the picture below is not quite flat on the table after I remove it from the gluing table. It appears distorted, in addition to parallax from the lens. The cross beams are parallel to each other and perpendicular to the planks.
Greeting @dockattner, I did not notice on the pictures.... but you are right. However, it is just the camera lens distortion. The cross beams on the plan are straight and parallel. Furthermore, I think that when I took the last picture the plan was a little bit deformed (upward slightly is some area after I remove the tape). Thanks for noticing, other may have been wondering too. Let me add a note to the previous post.
Lower middle deck: The lower deck was completed today. Doing the deck off-ship is convenient but a LOT of tweaking is needed afterward to have the deck fit well.... I mean a few days. I'm happy with it now. Next, the front bunkbeds deck... after a small break.
View attachment 579820View attachment 579821
That’s looking very nice and tidy, Loracs. A lot of fitting and neatly and tightly finished with also a nice color combination of the wood.
Thanks a lot! Indeed, I like the Boxwood/Pear Wood combo too. Like you, I'm planning on building the walls in light color (boxwood) and add lights. This should give a nice contrast to the interior and increase visibility.
Building Walls: This is the first wall beside the captain's deck. I included two doors for access to storage under the deck. Building those walls is not that obvious to do... shout-out to all the who did it before me. The easiest way I could find was to use the frame plan as a guide. Using CAD helps a little.
Version 1: had fitting problems and I used 3mm planks for the frame - which was way too big, I switched to 2mm.
Version 2: I cleaned the glue with a damp rag, which I will never do again because it warps the wall.
Version 3: Finally... got one done. The top bar will be cut later but will be used to anchor/glue the wall to the side frame 42. However, I just realized - "after posting" of course - that the doors are a little too high. A mistake that I will keep. it won't really show later.
View attachment 580933View attachment 580934
Very well done Loracs.
thanks all... those walls are a little tricky but look so nice at the end. Worth the effort.
