L'Orenoque Mamoli 1:100 scale
I decided to do a mockup of the fore and mainmasts based on the lengths given in the Magellan plans. 28 meters lower masts 20 meters topmasts. So, 280mm, less the distance from the bottom of the keel to the top of the deck (yellow line) and then 200mm less 40mm doubling (red line). Looks very tall - too tall?
Magellen gives 17M for the topmasts , not 20 so you are probably 3CM too tall.
So with that correction and some other adjustments I have the heights and proportions of the masts figured out. They will be just a little taller than the first versions and definitely not so spindly
Grant! Thank you for the compliment!
BTW I've been meaning to write about the case you built for Bounty. You should be very, very, very happy with the price. I know you assembled the case yourself, but the materials were amazingly inexpensive. All of my models are in plex cases with plex bases - here's the shocker - The cases cost me almost $400 each:eek:. And I have to drive 4.5 hours, round trip, to pick them upROTF Although I can't say for certain that Billig's HMS Warrior is the next on the stocks, she is here and calling my name - the case will be something like twice the price :eek::eek::eek::eek:Exclamation-Mark
Blessings. Peace. Gratitude.
Chuck
Good morning Chuck. Wow that is crazy expensive. Include the petrol (gas I think you guys call it) and that is no cheap case. Eish!
If HMS Warrior calls your name you should answer;)- she will be an impressive Chuck model.
Cheers Grant
What ho, shipmates! First, thank you for the anniversary wishes! We had a good weekend!
Second, here's the re-do on the sticks. A little more heft is better - thank you, Paul! Next time don't wait to tell me that something is out of scale ;) !
As you can see, and even if you can't, I could, the doubling of the bowsprit and jibboom leaves too much room between the two. Yes, I re-did that! Happily, I was able to cut the caps in half and scrape the remainder from the spars - I did a less than throrugh glue job! Yes, I glued them up - impatience!!!!!ROTFROTFROTF At least I didn't have to re-re-re-turn those spars.
The tips of the topmasts are all about :eek: or approximately 2mm. That's 7.87 inches. Too thick? Paul - looking at youROTFROTF
Have a beautiful day!
Chuck
I decided, after the re-re-re-do of the bowsprit and jibboom, to glue the caps, make and install bees and the jibboom rigging spreader called for in the plans. I think I still need to thin the arms of the spreader a bit. Here you go!
lo jib rigging spreader 1.jpglo jib rigging spreader 2.jpglo jib rigging spreader 3.jpglo jib rigging spreader 4.jpg
What ho, shipmates!
Progress, at a glacial pace, is being made. Questions now. Pictures later. ;)
Mast hoops: Yes because jackstays weren't a thing yet - at least not aboard these ships. So, mast hoops on all lower masts. Mast hoops on mizzen topmast?
Woulding: On lower masts? All three?
Crows feet? - I'm itching to do it on the fore and main and with Martin's theory that the French Navy was a decade or so behing in adopting modern rigging practices - puts the rigging around 1835 - Please someone stop me!!!!ROTF
Chuck
Hi, Chuck.
Since I couldn’t find specific original plans for L’Orenoque itself in my library, the answers are based on how similar era ships were handled and general rigging practice.
According to: Elements and Practice of Rigging and Seamanship, traditional square-rigged sailing ships (even late ones like L’Orenoque still had) often used hoops on mast sections where spars and rigging pass around the mast, mostly on lower masts, and often on topmasts too, depending on construction. Mast hoops help keep the spars (yards/topyards) aligned and rigging manageable. So expect hoops on the lower masts and also on the mizzen topmast if it carried spars or if rigging passed around it.
  • Lower masts: nearly always have hoops where shrouds and tackles pass.
  • Topmasts often do have hoops too, but fewer and smaller than on lowers.
  • Mizzen topmast: yes, if it carried yards or stays, it would usually have hoops sized for those lines.
Woulding (Wooling?) on Lower Masts — All Three? ;)
On ships of this period, you would generally wrap the mast with thin strips of wood or canvas before serving with rope (“woulding” or sometimes spelled wooling), to protect it and create a smooth surface for shrouds/serving. Normally, it should served all three lower masts that had shrouds and tackles.
  • Lower masts very often were served/woolded where shrouds, stays, deadeyes and hoops were rigged.
  • It was common practice on all three lower masts where rigging loads concentrated.
Crow’s Feet?
Crow’s feet are small lines that go from the mast top rim outward to stays or yard lines to keep canvas, studsails, or awnings clear of the mast and tops. They are a rigging feature you see on many period sailing ships.
  • They usually run through holes on the rim of the mast top and attach back to stays or to blocks on the rigging.
  • Their function is to keep the foot of the sail from rubbing on the top or rigging and to support canvas/awnings.
  • They’re not structural — they’re rigging detail.
So crow’s feet can be included around the mast top if you want that level of accuracy — especially if the top has euphroe or holes for them.
I would say hoops for the lower mast gaffs, but i would set the mizzen topsail flying.
wooldings or some sort of iron band are plainly visible on this picture
crows feet i have no idea, but 1835 , why not, if it gives you pleasure , not understood the attraction myself...ne_sai10.jpg
Crows feet? - I'm itching to do it on the fore and main and with Martin's theory that the French Navy was a decade or so behind in adopting modern rigging practices - puts the rigging around 1835 - Please someone stop me!!!!ROTF
10 years behind is still 20 years AFTER they went out of style.
Hi, Chuck.
Crow’s Feet?
Jim! Thank you for being an encyclopedia for me! Love it! And very very helpful.
Blessings.
Chuck
crows feet i have no idea, but 1835 , why not, if it gives you pleasure , not understood the attraction myself...View attachment 582366
Martin! Thanks for the picture and the thoughts on the mizzen topmast hoops. I don't know the name of this abridged lateen spar (red arrow) but I was pretty sure the sail would be set flying.
You don't love crows feet :eek: :eek: :eek:
ROTF
Blessings.
Chuck
Jerry!!! I knew someone would answer my plea to be stopped!:eek: Thank you! I guess I'll have to build the Royal Caroline at some point.ROTF
BTW - I'm about to be bitten by the scratch building bug - just between you and me and our shipmates - The Admiral recently gave me a bonus and I am about to pull the trigger on Blue Jacket's Kearsarge kit. That led me to look for plans. That led me to the National Archives which led me to the discovery of of the Civil War Kearsarge AND the predreadnought Kearsarge BB-5 with plans in 1/8 and 1/4 inch scales at the National Archives!!!! ALSO - when I was on the French plans website about a year ago I saw plans for a USS Missouri sidewheel frigate;) Also asked National Archives for those plans AND for the predreadnought USS Missouri BB-11!!! See, I was thinking to build the USS Susquehanna from scratch based on the plan set I bought of McCardle's model - But since Missouri is my adopted home state - you guessed it - 1/96 scale sidewheeler and predreadhought USS Missouri models!!!!
Yes. Lost my mind:p:p:pROTF
Blessings.
Chuck
