Thank you so much for your kind words. It is nice to hear this from the leader of the Bluenose group!Congratulations on reaching this milestone, Rob. With all the curves, it's always quite a challenge.
Rob
Thank you Ted, Good to see you here! I remember you jumping in and doing a fantastic job with your POF Bluenose! That was some learning curve! Be forewarned that this will be an on again off agin build, as I am building this in Arizona but live mostly in Connecticut.I have joined your build. Lookin nice and very well executed. I’m looking forward to seeing this one get built.
That's fine with me. You make me want to build another Bluenose. I think I could do a bang up job on the repeat project. I'm currently in my second nursing home. The VA moved me as the other place kept getting me sicker due to incompetence. In fact the feds filed elder abuse allegati on ns against their doctors.Thank you Ted, Good to see you here! I remember you jumping in and doing a fantastic job with your POF Bluenose! That was some learning curve! Be forewarned that this will be an on again off agin build, as I am building this in Arizona but live mostly in Connecticut.
Rob
Thank you for your kind wordsMy prayers have included your speedy recovery! I find you doing your work when at a nursing home remarkable. Hopefully you will soon be tinkering at your home workshop. I am currently at the sand, maybe a little wood filler, sand again stage. The hull is getting smoother and smoother but
I am sure you also had a hard time figuring out when smoothie enough is smooth enough.
Rob
As always, Thank you Grant for your encouragement. I am happy with how the hull came out. I ascribe it to luck and learning from others.Good morning Rob. Your planking came out really good - Kudos.
