L'Artésien 1764 - 64 Kanonen-Schiff in 1:48 nach Plänen von Jacques Fichant
Now I understand what you're getting at. :) No, the keelson was crafted according to the plans and glued in place after some minor adjustments. The nailing is purely for aesthetics.
Hi Barbossa, I'm a bit confused about the nailing. According to a description from that period, the fastening method is quite different. If you'd like, I can send you the description in a private message. Frank
Hello everyone!
Thank you very much, shota! :)
After attaching the inner deck stringers and the outer decorative moldings, I achieved sufficient rigidity to raise the ship to its final height. I had some concerns that the frames might not be of uniform thickness due to the sanding I had done earlier. Fortunately, this turned out not to be the case.
Regards
Andreas
Hello everyone!
Many thanks, Richard
The passageway to the quarter gallery has been constructed. Additionally, I had overlooked a decorative molding, which has now been added. The upper two wales were also fabricated, their heights measured, and then installed. For this model, I have decided against using India ink for blackening, opting instead to rely on naturally dark wood. I ruled out ebony; however, I was unable to find a suitable source for dark hornbeam online. Consequently—back when I placed the order—I settled on Mansonia Beete. It currently appears somewhat light in color, but during the final oil treatment, it will darken significantly, approaching a black tone.
Regards
Andreas
Hello everyone!
Regards
Andreas
Hi Barbossa, I was wondering: are you just following the monograph, or are you also reading any books on construction? Frank
Many thanks, colleagues, for your kind words! For the *Artésien*, I am working strictly according to the plans. However, Boudriot's volumes on the 74-gun ship are always kept close at hand when it comes to the construction.
Hello everyone!
Regards
Andreas
Dear Andreas
the wales on the hull of the ship looks outstanding!!
Hello everyone!
Many heartfelt thanks for your words of praise.
In the meantime, I completed the treenailing. To do this, I drilled 0.3mm holes, filled them with wax, scraped them flush, and "polished" them with steel wool.
For the sheer strakes, wooden treenails were used, and these are depicted as standing proud. I first saw this technique on Dmitri Shevelev's Russian forum. To achieve this, I drilled the treenail pattern, sawed a square rod from Mansonia wood, and sharpened one end to a point; this point is inserted into the hole and then snapped off.
I then carefully sanded it down to the desired height using 320-grit sandpaper. Afterward, I finished the surface using 800-grit sandpaper and steel wool. This entire procedure is repeated—for the sheer strakes alone—approximately 2,000 times.
Regards
Andreas
