It take time to be as good as Mike and Dave. As I have said before: keep up your great work Don.THANKS DAVE WILL TRY IT have progress pictures to post of dry fitting, not as good craftmanship as others but it is the best i can do still learning.
Or use rubber cement. If you can't buy it from the art/craft store, you can go to a tire repair shop, it the same stuff to fix punchers in the inner tubes.Hi Don,
You can try two-sided tape, it would be easier to remove than glue.
Mike
