Thanks, Nigel!!! Just to clarify who is Dr, Mike (Mikhail Bezverhniy) Rusian ship models builder GuruJust for clarity,a pic of a flexicurve or 'plastic snake' as Dr Mike calls it.
...this is more for everyone else, as you well know Mike and his work.Sorry Jim,Dr Mike is much easier for me as I can never remember how to spell Mikhail's surname![]()
I agree with Jim - with this wood, it will be a beautiful hull - Great work and thanks for sharing with us your steps
Hi Nigel, agree with you about the Dr Mike's videos. I have about 10 of his videos on model ship construction.
Hello,...
Slightly unrelated,but I wonder if anyone can point me in the right direction regarding the connection of the two frame halves.After hours scouring the French forum I have found that the futtocks were secured with 4 bolts driven from one side and 2 bolts driven from the other.
Nigel
I knew, that you know it - ThanksHello,
Sorry, I did not see that question.
In French construction, three bolt are placed to tie each scarph between the two pieces. These studs are square, the head is a little bigger (1/12 more) and they are riveted on a square ring (ferrule ?) embedded in the wood.
Here is a diagram based on the drawing of JC Lemineur:
Regards,
GD
Hello,
Regards,
GD
here is the full list Dr Mike's videos
I recommend to anyone who hasn't seen these to take the time and watch them.There are some great techniques shown in the footage.I almost forgot the one about using a kitchen toaster to bend planks!I am sure Gerard will answer this question .....Thankyou Gerard that is most helpful.Do you know if there is a set rule between frame thickness and the bolts diameter?
Kind Regards
Nigel
I checked the information given by Jean Boudriot in the 74 gun ship book (younger than your vessel), maybe it is helping also.
View attachment 90474 View attachment 90475
If you do not have this book I would like to recommend it as an additional basis for the hull construction
Link to the Book Review:
Book review - THE 74-GUN SHIP - Volume 1 - HULL CONSTRUCTION" (Set of 4 Volumes) - by Jean Boudriot
Book Review: THE 74-Gun SHIP / THE SEVENTY-FOUR GUN SHIP A Practical Treatise on the Art of Naval Architecture 4 Volume Set (Set of 4 volumes) Overview of the Content of all 4 Volumes Here: Volume 1 - HULL CONSTRUCTION by Jean Boudriot english translation by David H. Roberts...shipsofscale.com
Here are the Look Inside views from the Book Review related to bolts, nails etc
View attachment 90476View attachment 90477View attachment 90478
Of course, there is a rule that is based on the width of the keel which is the absolute reference in the construction..Thankyou Gerard that is most helpful.Do you know if there is a set rule between frame thickness and the bolts diameter?
Kind Regards
Nigel
