Perhaps Holly as a white substitute for the officers’ quarters? I’m not sure how it will oxidize, over time, though.
What a joinery, man. I'm speechless.I have done the initial fabrication of the Rider frame.This is in African Red Padauk.The Monograph states that the full interior on this vessel was Red Occre bar the officers quarters,so the full interior will be Padauk bar the decks,which will be Pear.
The upper futtocks are not attached and will not be until much later.These penetrate the lower gun deck.The base has been sanded to the bevel of the floor timbers.
Final pics how the item in location,it will need setting up properly to scribe both sides to follow the hull interior minus the internal planks and strakes (3mm).I will leave a little meat though for final tweaking prior to fitting.
Kind Regards
Nigel
View attachment 119943View attachment 119944View attachment 119945View attachment 119946View attachment 119949View attachment 119952
, so I am up to date with your log, Nigel, and I just have to say - WOW!Perhaps Holly as a white substitute for the officers’ quarters? I’m not sure how it will oxidize, over time, though.
.The larger diameter will make it easier to attain fair curves on the frames edges.
Glad to see you back to work, Nigel! Has the skin irritation fully abated?
...t is time switch to the black hornbeam, perhaps?I had a real bad reaction to Ebony once
...t is time switch to the black hornbeam, perhaps?![]()
Be careful that can turn into a whole other hobby by itself. Mine got lengthened, digital readouts, quick change tool posts, grinder attachment etc. It's a great tool for hobby sized work, and beefy enough to turn steel for small jobs.
Not all is rosy though,I have just opened the box to find it has had an impact on it's end cracking the belt cover.I have had Machine Mart on the phone and then emailed them pictures,they are talking about sending a replacement machine rather than just the cover.We shall see,currently NOT happy
