- Jan 26, 2017
It's a beautiful cannon Knut. I have the same lathe of Proxxon, I made Pickle's cannons by the lathe too but I am not so happy with the look of my cannons. What type of blade do you use or do you use only sand paper to make it? Thanks in advance.Lathe - cannon
I have never done this before, first attempt.
The cannon is made of birch, drilled hole for shaft, I made dust extraction of cardboard, saw some mistakes, see arrows, then loosen, lock screw (arrow), then everything collapses, but I'm happy since I've never tried this before, the next try will probably be a lot easier.
Regards-
