OK ALL I AGREE WITH GILLES, NIGEL, MAARTAN will go for beveling latter on after frames are on the keel, nigel I will show you some of the small sanding devices that i have, ALL CHECK THE BUILDING LOG UPDATES. Don
Hello,
Please, we need your help...
One of our fellow modelers is having a dilemma building frames for his model.
The construction of his frame is the traditional 2-layer frame.
To familiarize yourself with his project, here is the building log: https://shipsofscale.com/sosforums/threads/le-rochefort.3325/page-23
He is using the method most commonly used: paper pattern for each part of the frames glued to lumber. The patterns are then cut out and prepared for assembly.
The problem is the following:
Once individual parts are cut and ready for assembly, the paper pattern is still glued to the part. As the frame is built in 2 layers, the layers need to be glued together. Leaving the paper sandwiched between the 2 layers is not a wise practice. So how do you assemble the 2 layers, and most importantly, how do you line up the parts of the top layers over the bottom layer?
Here is how I personally build my frames: https://shipsofscale.com/sosforums/threads/le-rochefort.3325/page-18#post-87714
We are looking for advice: the most important part of the problem being how do you make sure the 2 layers line up once the paper pattern has been removed from the joint area between the two layers?
Your input is much appreciated.
Thank you.
G.
Would it be possible to glue a pattern to the forward face of the forward half of the frame and glue a pattern to the aft face of the aft half of the frame? Then the two halves can be glued together, leaving paper only on the two exposed surfaces where it can easily be removed later. If the outer edges of the frames are tapered to follow the lines of planks then cut the inner portion of both frame halves and glue them together before cutting the tapered outer surfaces.
I have never assembled such frames, so I apologize if this suggestion is not practical for any reason.
Good luck & Happy Modelling!
Steven
If you are open to different approaches to scratch building frames, Bob Hunt, LauckStreetShipyard.com, has a wonderful focused practicum for frame building using the HMS Roebuck Harold Hahn plans. It provides a great review of technique. However, you may well be past where this practicum would help. Bob has also published in booklet form various aspects of scratchbuilding to include framing techniques that may also help.
The dilemma as I understand from the posts is the paper pattern glued to the frame and how to get good fit with the paper pattern still in the way. I think you feel you need to retain the pattern to continue to help you with a good fit of the parts? My approach is to first have two copies of the pattern...one for initial cutting aNd shaping, and one for final fitting. Glue one copy to your wood stock with rubber cement which will allow for easy removal of the paper. Carefully cut out the parts to the pattern and sand to close tolerance. Remove the remaking paper pattern from the stock. Use the second clean copy of the pattern to help in continuing to shape the parts while dry fitting for final fit. Once satisfied with the fit glue up the parts then continue to use the pattern for final shaping. You should have a well formed part ready to install on the keel at this point.
Now...after digesting everyone's thoughts if you are still have problems, or we missed your concern, restate your question so we can refocus on what you are trying to do.
Maybe I'm naive or not reading correctly, but why aren't they clued to the outside of the frames (either side) No sandwich of paper.So before anyone else misinterpret my reply, here is what the original question (and context) was:
"Once individual parts are cut and ready for assembly, the paper pattern is still glued to the part. As the frame is built in 2 layers, the layers need to be glued together. Leaving the paper sandwiched between the 2 layers is not a wise practice. So how do you assemble the 2 layers, and most importantly, how do you line up the parts of the top layers over the bottom layer?
GO JUMP....
From the horizontal tops- or bottoms if your building in the Hahn styleThank you @stuglo
That is exactly what was being done.
The question is:
How do you make sure the patterns on one side match or are lined-up with the pattern on the other side? Basically, How do you line-up the 2 sides?
I made 2 paper patterns, one for each side(layer). Cut at each top (and vertical cut bottom for even more accuracy) and align with patterns covering outer sides . Just remember the direction of the frames changes half way (at least in the ones I've seen)Not sure what you mean by that.
Although the Hahn method is not entirely used, the method actually is not important.
What we have is:
1) Frame built in 2 layers.
2) One layer has frame pattern glued on it: top layer or bottom layer is irrelevant.
3) The other layer does not have patterns.
What we want to do is to have the same frame pattern or outline on both layers once the layers are assembled to form a complete frame.
Question:
How do you achieve alignment of the patterns on both sides of the frame to achieve beveling prior to installation on the keel?
Thank you.
G
Is it practical to shape the taper before installation on the model? The taper on any frames away from midship vary considerably from keel to gunnel. Some articles I have read suggest sanding, or filing, the tapers after all the frames are firmly in place. I have not built this type of ship, so I don't know if what I have read is practical, or not. Based on the difficulties you are experiencing, it might be worth a try. Perhaps mount a few test frames on a scrap piece of wood like the keel and try tapering in place. This way all frames can be cut without any taper, the patterns should be sized for the larger face of the frames; aft side of frames forward of midship and forward side of frames aft of midship.Not sure what you mean by that.
What we have is:
Question:
Thank you.
G
Best wishes.
Steven
