- Dec 1, 2016
what gives the hull its shape is the bevels inside and outside of the frame the trick here is that bevel is fluid and changes from the bottom to the top of the frame which you can see in this cross section at 2 locations on the frame
another issue with drawing it is rare these bevel lines are exact because they may slightly change when a frame is installed into the hull. model builder will give the hull a final sanding to match all the frames in a smooth continuous surface.
problem you can not sand a 3D model to a final shape
