The ship carpenter enjoys and makes progress:
The wall between the dry hold and the 2 transverse bunks:
At the front there are 2 cleats on which the floors of the 2 bunks will rest. The dry hold is intended for the storage of provisions for the crew.
Made a first draft for the vertical ladder in the hold:
A bit inspired by the climbing holes in the planks in the aft hold. It must be a bit of a fool's test for those fishermen with their wooden shoes. Need to finish it some more.
The dry hold only has access via a hatch on the deck:
The dry hold also has a shelf. The ladder helps support that shelf.
Soon only visible through the hatch opening because there will be another wall at the head of the hold and transverse bunks.
Everything is still dry-fit for the time being because I still have to figure out in which order I am going to build everything up. Perhaps the longitudinal bunks with their sloping wall first?
Good morning Peter. It is beyond me how you got those curved inner planks so good within such a confined space......skills my friend. Cheers Grant
Thanks, Grant. First I thought you meant the curves on the side of the wall. But I suppose you mean the lengthwise outside wall planks.
Just plank by plank with a lot of fitting and sanding and one by one gluing.
For the wall it self:
Also plank bij plank, starting with the 1st in the lower corner. When the curve is correct than the 2nd, 3th and 4th.
This looks exactly what we’ve come to expect; marvelous.
True story
Thanks, Johan and Grant. Expectations (and habit) are a bit of a pitfall.;) In the meantime I know quite well where the boundaries are. But as I wrote: plans are meant to be changed. So, boundaries are there to be crossed, principles are there to be deviated from.:)
One 'module' further: the 2 transverse bunks:
Everything dry-fit, so not yet completely tight. Some small brackets on the wall and floor to help with alignment.
On the inside slats are the two floors of these cages.
With the closing wall on the end side:
An little angled seam at the bottom. That goes away when I press on the wall and remove the slight bulge in the watertight bulkhead.
At the front the 2 'opgeklampte' sliding doors.
Of course they can be opened:
No protruding parts. So no buttons but finger holes.
Seen diagonally from above:
With the height of the walls, always kept an eye on the sheer of the deck. That the walls do not push them up.
The 3 arrows point to the sloping wall for the other 4 bunks with their dividing wall.
'מודול' אחד נוסף: 2 הדרגשים הרוחביים:
הכל בהתאמה יבשה, אז עדיין לא הדוק לחלוטין. כמה סוגרים קטנים על הקיר והרצפה כדי לעזור ביישור.
על הדקים הפנימיים נמצאות שתי הקומות של הכלובים הללו.
עם הקיר הסוגר בצד הקצה:
תפר זוויתי קטן בתחתית. זה נעלם כשאני לוחץ על הקיר ומסיר את הבליטה הקלה במחיצה האטומה למים.
בחזית 2 דלתות הזזה 'opgeklampte'.
כמובן שניתן לפתוח אותם:
אין חלקים בולטים. אז בלי כפתורים אלא חורים באצבעות.
נראה באלכסון מלמעלה:
עם גובה הקירות, תמיד פקח עין על הדק של הסיפון. שהקירות לא דוחפים אותם למעלה.
3 החצים מצביעים על הקיר המשופע עבור שאר 4 הדרגשים עם הקיר המפריד שלהם.
בברכה, פיטר
I have run out of words of praise and admiration
Making the 4 bunks placed diagonally forward was quite a challenge. I will take you through some steps in the production process.
The bottom of the lower 2 bunks on a frame:
Made in such a way that it can slide around the partition wall that has also been made.
On top of that the supports for the floor of the top 2 bunks:
Also with the floors and it can be slid between the walls again. I need the floors to slide up the shutters.
The wall had to be treated with the necessary care:
It consists of 26 slats of 3.0 x 0.7 mm. With 4 recesses for the profiles of the deck beams. Once the wall has been finally installed, it will be neatly finished at the top. Together with covering the metal deck profiles with wood.
Placing the wall also receives the necessary attention. It must be inserted at an angle and then tilted with the 4 recesses along the 4 deck profiles.
That's why I'll have to install everything in reverse order later. Because if the 2 transverse cages are already there, I will never be able to tilt this wall in.
With a lot of trial and error, this worked:
Then drew the 4 recesses at the back for the openings for the 4 shutters.
After making the shutters, place the necessary slats at the back so that the shutters can slide:
I can get that back in place too.
With the dry-fit test installation of all parts:
Yes: once again theory and practice come together. It is standing!:)
Now take everything apart again, clean it thoroughly, put it partly in linseed oil and then finally glue it into place.
My next jar of pickled herring will hold special meaning!:p
