Great caulking imitation on the deck, Gibby. If you don't mind, the caulking is only used on the deck and the hulls, it wasn't used on the walls and bulkhead compartments\deviders.Here I used black nylon embroidery thread
Makes sense. I guess you could say I was being somewhat extra with lolGreat caulking imitation on the deck, Gibby. If you don't mind, the caulking is only used on the deck and the hulls, it wasn't used on the walls and bulkhead compartments\deviders.
Thats pretty cool, thanksYes sir. I have a video of how I did it. But yes I place my middle or king plank then the thread then another plank
No problemThats pretty cool, thanks
Hey, Paul. The caulking imitation can be done in many ways. The most commonly used would be to blacken the edges of the planks with a black pencil (B or 1B), some likes to rub the edges with a graphite pencil (not my favorite). Those methods are simple enough and give a decent result. One of the advanced methods is to use very thin black paper. On the scale of 1:48, it should be about 0.6 ~0.7mm. I called advanced because it will require some practice and careful gluing the paper.
I also know about painting the edges, but I never use this method.
Sorry for the Off-topic, Paul.Makes sense. I guess you could say I was being somewhat extra with lol
We oftentimes want to emphasize the timbers of the wall, I mean that it was built from separate planks. One of the ways is to bevel the edges from both sides. when glue, the shadow from bevels will give that representation
Yeah! Paul that looks great! Those finishes really make her pop
Greetings is this stain waterbased or poly\oilbased? How fast does it dry and how deep does it penetrate the timber?Ok....took a break from Toothpick Trennals(only did 4 deck beams worth today), and gave a final sanding to the Star Board side frames and wales. Found this Ebony Stain at the local hardware store, and tried it on the wales. Seems to be good. Also Varnished the Frames below the wales with their first coat today
ottimo ,molto bello complimentiSi signore. Ho un video di come l'ho fatto. Ma sì, posiziono la mia tavola centrale o re, poi il filo e poi un'altra tavola
