Glenn, thanksLooks great Paul. Nice joinery!
Glenn
The treenails look a bit dark for my taste. I would use lighter timber, to make them more subtle, birch toothpicks, for example.What suggestions do you have for tree nail look? Thanks, Paul
Size wise the top ones look better. I wonder if a bamboo wood nail would be lighter. I know model shipways sell bamboo toothpicks
Although bamboo is not a desired timber to use as the treenails. If you crosscut flush you will open hundreds of small dots (fibers), this will affect the overall appirance. But your choice will be always preferable to you.Model Shipways Bamboo Toothpicks 200 STICKS/BOTTLE - USE AS TRUNNELS
Jim, what do you recommend instead? thxAlthough bamboo is not a desired timber to use as the treenails. If you crosscut flush you will open hundreds of small dots (fibers), this will affect the overall appirance. But your choice will be always preferable to you.![]()
In my post above, I suggested using Birch toothpicks, this is what is commonly used in our shipbuilding community. I mean many of our members love this material as the treenails.Jim, what do you recommend instead? thx
ThankJim, what do you recommend instead? thx
Similar to this
Yes sir. I have a video of how I did it. But yes I place my middle or king plank then the thread then another plankAre you must laying the thread in between as you lay the next plank? Thanks
Hey, Paul. The caulking imitation can be done in many ways. The most commonly used would be to blacken the edges of the planks with a black pencil (B or 1B), some likes to rub the edges with a graphite pencil (not my favorite). Those methods are simple enough and give a decent result. One of the advanced methods is to use very thin black paper. On the scale of 1:48, it should be about 0.6 ~0.7mm. I called advanced because it will require some practice and careful gluing the paper.Jim, what do you recommend for simulated caulking between deck planks, if anything? I have used a black crayon on past models to simulate. Thank you, Paul
