Good to know. I've used water-resistant PVA and didn't know there was a way to disassemble it.I use watertight PVA so I don't have another option than Acetone.
Good morning. My next ship will be an attempt at a POF. reading through this I'm not sure I am ready for such a project. Your frame work looks brilliant and i, sure these problems will find a solution. Cheers GrantPROBLEM: While related to the above problem, this is a separate one, and to be honest, very concerning. I assembled the templates today, and put them in place, marking the A and B locations as carefully as I could, as outlined in the instructions. This is typical in how A and B are located:
The instructions clearly show the bottom of the top strip to be at level A:
and the bottom of the lower strip to be at Level B (although somewhat less clearly):
I could not determine exactly what height these strips should be in areas other than the 4 templates, so was comparing the drawing with the template, and found what I think is a huge error. After more ShipsOfSale.com searches for this problem,
During the process of solving the previous problem (if in fact I have solved it), I found this post by Uwe in tedboat's Granado build, giving an entirely different location for the lower strip: rather than the bottom being at the B height, the TOP needs to be at the top of the notch ABOVE the B point!
This is a huge error, IMHO, one that could ruin the entire build. Well, okay, it's only 2-3mm, but that's 2-3mm less room for everything below that point, and I think it would really mess things up.
SOLUTION(?): I don't know. I can use Uwe's instructions at the four templates, which appear to raise the lower strip about 2mm. Do I also raise the point of the bow 2mm? Or I guess take measurements off the drawing? The templates are good for height at 4 places, but there's nothing else to determine these heights, which are quite critical. I wonder: Does a strip of inside planking go between these two strips? If so, that might be a good way to locate one from the other, at least. I don't know, this is frustrating. The most comprehensive builds of this model don't have any of these questions mentioned, I believe.
I think it's time to sit still and study, rather than build. I'm good at that, at least.
I felt exactly the same way, as I've never built a POF until now, but it's actually gone quite easily. In fact, it has taken much less time than I thought it would (but then I have been using power sanding for most shaping, and I'm not doing the brass and iron pins that others are). I do have some questions on the above, and want to research and think about it quite a bit, because I know not doing something right at this stage will have horrible repercussions later!Good morning. My next ship will be an attempt at a POF. reading through this I'm not sure I am ready for such a project.
Thanks very much. If you really want to see brilliant, I refer you to Uwe's build, but I think it looks okay so far.Your frame work looks brilliant and i, sure these problems will find a solution. Cheers Grant
Good morning. Wow a lot of work and starting to look like a ship. You are doing a fine job on this POF. Cheers GrantContinuing on with strip 'C', the patented Signet Torsional Clamping System® is used once again:
I'm feeling most of the strips are created a bit more curved than necessary, but that's probably just me. Most require more bending on each end to fit tight against their neighbor.
Thanks very much, Grant. Yeah, it's starting to look ship-like. ;-)Good morning. Wow a lot of work and starting to look like a ship. You are doing a fine job on this POF. Cheers Grant
