Thanks for the compliment. I'm learning as I go. No frustration, just a lot of trial and errors to get the right look.I am very happy that you found the solution Jan. Those bends look A1.![]()
The bent pieces look great! RichThe Bends:
I'll never admit how many tries it took. But I think I've got it.
Jan
Practice makes perfect, they say! Good job!The Bends:
Jan
Maybe if not perfect . . . hopefully better in my case. RichPractice makes perfect, they say! Good job!![]()
If you can do the starboard side correctly, then you can do the port side correctly. It may not take the same number of attempts (or be as easy as the other one), but I have no doubt you will succeed.![]()
Hi Jan.Bumblers Notebook continued:
The Port side of the Boiler deck structure is finally ready to be set in place except for the curved section at the bow. It's a "do over" since I misinterpreted the directions, had to take sections apart, etc. The soaking technique to glue parts worked well, but also left the long section of the structure a bit warped. My unorthodox method for fixing that, was wet the piece, place it between parchment paper, place that between pieces of 1 X 2 boards and use every clamp that I own and let it sit for a couple of days.
The result.
The fix worked out well and the piece has been set in and glued. Fortunately I had ordered and received a couple sets of spring clamps a couple of days ago.
The next pice of the puzzle was to repair the damage my enthusiasm caused to the piece that fits the curved section missing in the gap that shows in the above picture.
I glued the required number of vertical pieces to two scrap 1 X 4mm mahogany planking pieces. Marked the location of the the door and cut in in the door windows.
Step two of the process was to score in-between the boards top and bottom and use a pair of needle nose pliers to cause a break in the 1 X 4mm pieces so the assembly could be bend into a curved shape.
Next step is to fit that piece, prime it and then add the battens before the final paint job.
It feels like I've been working on this part for the last two years, I'm looking forward to moving on to the Hurricane deck build portion.
Jan
Hi Peter, a year ago I would have given up and let the build collect dust on a shelf. But now, following all the great build logs, admiring the variety of techniques used to overcome build problems and also getting a lot of help, suggestions and encouragement from SOS members, I’ve gained a lot of confidence. I’ve managed to bumble my way through four builds, each one requiring a different technique, many “do overs”, but all were completed. I think I’ve reached the stage of looking at a build step from different angles and thinking about what’s required versus just dabbing on a glob of glue and moving on to the next step. This build is a bit more complicated than my last but hopefully a good skill builder for build number six (The Duyfken) .Despite the obstacles, it is good to see that you still manage to find a solution.
Hi Heinrich,my advice is just to buckle down, finish that piece, mount it and then its onwards and upwards! Don't overthink the process too much!
My thoughts exactly!That is not cool. Does that section get planked over? In other words, can you not make the hole in the correct place and simply plank over the incorrect one?
Use the correct side as a template to locate the correct hole location. Cut out hole, fill in incorrect hole location, then plank or veneer the deck. Problem solved…no need to wait!
I think Peter used black sandpaper to simulate roofing material. It looked very good IMO. And it can be painted if you wish. A fine grade would probably be best for scale. Maybe 220 grit.This section of the build is the roof of the boiler deck or the floor of the hurricane deck. I think the idea is to paint or cover the area with roofing material.
Right on, that’s the plan. I was trying to figure out how hide the joints of the four pieces and was contemplating covering the area with silkspan to simulate roofing. But I think your suggestion is the best alternative. Now I need to order planking material to make the fix.
Jan
