It’s FAMOWOOD Latex Formula, Wood Filler. Manufactured by Eclectic ProduCT’s, Pinevila, LA. The website on the container is FAMOWOOD.ComWow Jan - based on the pictures that stuff works wonders! I can't see any remains of those joints. What is the name of this product?
HI Paul, that "curve" is mostly distortion from the iPhone camera angle. The deck is not glued to the underlying structure yet. Technically there is a slight down curve from Port to Starboard and a major up curve or sort of swayback from the stem to stern with the center of that being about midships.Beware the 'curve' in the roof/deck - either a camera angle effect or something is not level.
Oops, I can see that now it is pointed out. That area is a little bit of warp in the ply due to the moisture in the wood filler. The center of your blue outline is where the dovetail joints of the four pieces of roof/deck were filled in. The ply is only 1/16 of an inch thick. I’ve gone a little overboard adding support pieces to the top of the Boiler structure so the deck/roof can be fastened and glued. Underneath the deck where the joints meet I’ve glued strips that should help straighten out that little bend. Heinrich says I overthink these things, but I can’t help myself, “once an engineer always and engineer “Perhaps there is here between the bleu lines a little curve in the deck, what Paul maybe means:
Well, we can shake hands, both overthinking our processen well.Oops, I can see that now it is pointed out. That area is a little bit of warp in the ply due to the moisture in the wood filler. The center of your blue outline is where the dovetail joints of the four pieces of roof/deck were filled in. The ply is only 1/16 of an inch thick. I’ve gone a little overboard adding support pieces to the top of the Boiler structure so the deck/roof can be fastened and glued. Underneath the deck where the joints meet I’ve glued strips that should help straighten out that little bend. Heinrich says I overthink these things, but I can’t help myself, “once an engineer always and engineer “
Jan
Wait up - I want in on the overthinking party too!Well, we can shake hands, both overthinking our processen well.That’s what we think…..
Warm welcome to you Paul, glad to have you in the group. We meet every Thursday in the Lounge, Den, Man Cave…… ? Wait I’m going to get back to you on thatWait up - I want in on the overthinking party too!
Wow, something from little ole Pinevile LA, I spent 14 years in the USAF in city across the Red River from Pinevile.It’s FAMOWOOD Latex Formula, Wood Filler. Manufactured by Eclectic ProduCT’s, Pinevila, LA. The website on the container is FAMOWOOD.Com
Easy application, dries in 30 plus minutes and accepts “most “ water based and oil based stains.
Jan
Barksdale AFB??? “BAD”Wow, something from little ole Pinevile LA, I spent 14 years in the USAF in city across the Red River from Pinevile.
Wow, lots of coffee to keep your energy constant.Thank you for the invitation Jan, but I have 10 days to get the WB to the stage at which the replica currently is. After that the shipyard will be indefinitely closed so I have to use these days - just build, build and some more building.
Is Nescafe really coffee???Wow, lots of coffee to keep your energy constant.
Jan
