Very nice joinery Shota. I hope your relative recovers fully!
thank you very much my dear friendVery nice joinery Shota. I hope your relative recovers fully!
thank you very much my dear friend for the compliment and the supportYour wales are looking good, Shota, I like the finish you applied.
I wish your friend a speedy recovery.
my dear friend HeinrichMy dear Friend. I urge you to re-think this cutting idea very carefully and when you have done so, think again. It is not a necessary requirement for a model to be cut in order to be a successful model. Both Maarten and Peter have incorporated the idea of cutting their models, very early on in their builds and I know that Peter, in particular, has made certain changes in his build to accommodate that. Please think carefully if you really want to do it.
Good morning Shota. Excellent….oh boy I cannot imagine doing that many tree nails and this is just the wale. Cheers Grantgood evening dear friends
In the last two days I continued to creat+paint the wale.
It was a challenging and even a little frustrating, because the first attempt at painting (acrylic paint, 4 layers) did not turn out in the quality I wanted to achieve and even worse. I had to scrape off all the paint and sand the wood panels.
today I sat down and repainted everything. I must confess that the difference between the two attempts is in the degree of patience and pauses between each layer of paint as well as the use of thin paint brushes. After I achieved the desired result, I also worked on treenailing the planks.
I have not yet finished cleaning the small paint residues left on the frames, I will do so in the coming days.
meantime have fun from the pictures, hoping that you will like the result.
Good night friends
View attachment 334912View attachment 334913View attachment 334914View attachment 334915View attachment 334916View attachment 334917
thanks my friend, it's not easyGood morning Shota. Excellent….oh boy I cannot imagine doing that many tree nails and this is just the wale. Cheers Grant
Dear AlexanderVery good progress, Shota
I don't know, how it looks in real but the photos show some gaps between the planks and a disturbing shine of the yellow color.
To avoid the gaps, a smooth background is necessary. The planks must also have a relative thickness (Minimum 1,5 mm) and a good preparation.
If there is still some misbehaviour of the material, some tools are helpful: Special needles to press the wooden parts to the right direction with some force. I also used these clamps to pull the planks together: Hatagane clamps.
For the colors I would recommend flat colors. For some types of colors its necessary to stir them very well to avoid shining.
Cheers, Alexander
Great work and detail. Love the hingesgood evening dear friends
Today I continued working on the sail room, it's almost completely ready.
Today I worked on the hinges - bending the edges into a circle into which the hinge was inserted, blackening the brass, fitting the door and windows and installing them stably. After that I prepared the fabrics for the sails which were placed on the shelves. In addition, making a rack on which blocks were installed/hung.
This is a concise description for long hours of creation.
What remains for me to make are the door and window locks, they will be in the form of a hook that goes down into a gap (a simple locking mechanism).
Good night everyone
thank you very much my dear friend, I appreciate your wordsGreat work and detail. Love the hinges
Did you use them in this way? (red is the frame, green three planks)Very good progress, Shota
Cheers, Alexander
Thank you for this fine drawing, Uwe. This is exactly the way I used the Hatagane clamps. Of course it only works, if the planks are not too weak.Did you use them in this way? (red is the frame, green three planks)
Otherwise I have my doubts, that the long element of the clamp is fitting in between two frames
thank you very much my dear friend, I appreciate your adviceDid you use them in this way? (red is the frame, green three planks)
thank you very much my dear friend, I appreciate your kind wordsHallo Shota, I have now found a little time to follow your beautiful work more closely. You have really made fantastic progress and your execution is very, very good. I like it extraordinarily.
Good idea!Did you use them in this way? (red is the frame, green three planks)
