In the mean time more then 400 copper bolts are in my hull. Just over 1/3 is finished.
To avoid getting bored by hammering and cup burr drilling I took a small side step to plank the lower stern.
This is the planking at a 45 deg angle with 4 planks in the top row and 3 along the stern downwards.
As the planks have to join the hull planks I have to trim a lot to get all angles correct. The first one to fit in is the bottom one. Before fitting the planks the edges are painted with dark brown ink.
For every plank I first tailor the free end at the correct angle. Then I roughly write off the size and shape.
Saw it and fit and sand and fit etc till it properly fits.
Untill all planks are fitted. And the surface flattened with a file.
On the top I make a freeze separating the lower and upper transome.
This freeze I make from a strip of 2,2 mm square cherry which I cut from a cherry billet.
The freeze I scrape with a profile I cut into a razor blade.
Then tap the strip with double sided tape to a flat surface and scrape it untill you have the preffered shape.
The freeze is glued in place.
The stern planks are not bolted, so these I treenail.
View attachment 217101View attachment 217102
And the bolts, thats still work in progress.
			Nice work again, I like the razorblade as shaper. I never think about to use these things for the job.
I had forgotten about shaping a razor blade for a molding scraper.  I don't need one right now but am going to give it a try as the Amati scrapers that I have don't have some of the shapes/sizes that I needed in the past.  Nice filing work bringing the siding and transom planking together with those difficult angled edges.  Rich  (PT-2)
